How much preload do you add?
Old Oct 13, 2003 | 07:18 PM
96z's Avatar
96z
How much preload do you guys add to your rocker arms? Ive always added 1/2 but there always seems to still be some clacking. Ive always tried to avoid more since I didnt want to bog the car down with too much preload.
What is theoretically best for best power? 0 preload?
Just wondering what everyone had to say before I go adjust the rockers again tommorow.
Old Oct 13, 2003 | 07:25 PM
AsianSensation's Avatar
I gave 1/4 turn past zero lash. Seems to be working for me so far.
Old Oct 13, 2003 | 08:31 PM
96z's Avatar
96z
So noone adjusts their own rockers huh?
Old Oct 13, 2003 | 08:34 PM
Transamdriver's Avatar
1/4 turn.
Old Oct 13, 2003 | 08:37 PM
12SCNDZ's Avatar
With the engine running...1/8 turn past "chatter".
Frank
Old Oct 13, 2003 | 08:44 PM
95 Z/28 LT1's Avatar
Super Moderator
I made a post like this a while back in the Advanced section and didn't get a whole lot of replies.
If you want the best answer and have normal style hydraulic lifters, then you want to push the plunger down into the lifter appx. .020-.060. This can be accomplished by either using a dial indicator, or scribing the pushrod with a known mark and then scribing it again after the preload is set. Then you measure the distance between the two marks.
That's according to Crane BTW.
Old Oct 13, 2003 | 09:10 PM
QCKZ28's Avatar
i did what frank, 12SCNDZ, did pretty much
with engine running, loosen rocker until i hear clacking and oil splattering everywhere, then tightened with with my fingers, until it stopped clacking (pretty much finger tight), then add 1/8 with wrench and lock the nut down.
Jesse
Old Oct 14, 2003 | 03:48 PM
96z's Avatar
96z
So the consensus is pretty much 1/4 or less huh?
Old Oct 14, 2003 | 04:19 PM
jkipp84's Avatar
When I did my cam swap, I initially set them at ½ then loosened/retightened them (one at a time) with the engine warmed up and running at ½ again.
I've had no problems, but if for some reason I have to remove the rockers, I'll do the final set @ ¼ next time.
Old Oct 14, 2003 | 04:20 PM
joeSS97's Avatar
1/2 turn,seems to work for me.
Old Oct 15, 2003 | 08:06 PM
96z's Avatar
96z
Which would be the most accurate? While the car is running? Also how do you guys adjust the passenger side? Do you just leave the alternator on?
Formula Steve
Sep 19, 2023 08:31 AM
NewsBot
Sep 14, 2015 09:20 AM
Aug 24, 2015 06:41 AM
Aug 7, 2015 01:26 PM
surreybrad
Jul 5, 2015 10:36 PM
