Whats normal RPM???? Please help
Old Oct 12, 2003 | 08:50 PM
stang_killa94's Avatar
I was driving down the street today and i noticed that if i got up to 50 mpg i had about 3,000 rpm but if as soon as i hit 50 and then let go of the gas the rpm dropped to 1,000 is this normal? Also at a red light it showed about 500rpm is this normal too? Im having serious probelms with my car where if i step on the pedal all the way it takes me about 10 secs to get to 20mpg but after that my cars picks up fine until i stop again........
Old Oct 12, 2003 | 09:39 PM
2hipbiker's Avatar
well its normal for it to drop but i guess not that much also you dont say if ur auto or manual, but i'm assuming automatic.... so when u jump on it and try to accelerate it seems that ur tranny is not downshifting properly... so u might have transmission problems.. try getting ur tranny fluid changed..
Old Oct 12, 2003 | 11:10 PM
You should get some engine braking when you let go of the throttle unless you hit the brake. If your engine is revving up and you are not going anywhere, then the tranny is slipping. Check the fluid level and condition (like if it is dark and smells burnt).
Old Oct 13, 2003 | 12:01 AM
97BBlackZ's Avatar
The RPMs will drop like that when you are in OverDrive mine normaly drops down to 1.5k so i dont know if thats normal
but if im in D then it will stay at those rpms that i am at and go down slowly
beltrunner
May 17, 2015 10:18 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
94Form
Feb 10, 2015 11:23 PM
edman
Jan 25, 2015 02:41 PM
edman
Jan 22, 2015 02:45 PM
