Intake problem please help..
Old Oct 13, 2003 | 12:03 PM
djn's Avatar
djn
Just installed a new K&N cold air intake and not sure its working right.
1995 Z28, when the engine is cold, at startup, I can hear it sucking air from somewhere around the main intake elbow area but as it begins to warm up, the suction sound tends to lessen, until it finally disappears completely, at that point you can start hearing the K&N sucking air.
Also, when I lift the elbow a little with my hand it causes the motor to start choking. The more I lift the elbow the more it chokes until it eventually cuts the air supply completely and the engine dies.
Is this normal or are there any suggestions that might help..
Thanks,
Old Oct 13, 2003 | 12:06 PM
Sounds like the bottom of the intake elbow is not correctly connected to the throttle body. It isn't unusual for it to "fold under" and not slip correctly over the TB. Check there first.
Old Oct 13, 2003 | 12:08 PM
BradZ28's Avatar
Either that or the rubber intake elbow is ripped. They don't last too long as rubber tends to crack after being heated and cooled so many times under the hood.
Brad
Old Oct 13, 2003 | 12:12 PM
djn's Avatar
djn
Thanks, I'll take a look just thought it might have a cold start valve or something causing it to draw air from somewhere else until it warms up. Noticed a 9-10in long duct coming from the bottom of the elbow straight down..
Old Oct 13, 2003 | 12:24 PM
There is no "cold start valve" on an LT1. The tube you see running down the front of the engine, from the intake elbow is simply a "silencer" tube, and is closed at the bottom. Nothing should leak in there.
Type_O_Negative_1320's Avatar
That would be the "donkey dong". You can remove it and cap the hole in the intake elbow with the bottom of a Pert Plus shampoo bottle and some tape. It doesn't do anything other than quiet the intake down a bit.
Old Oct 13, 2003 | 12:31 PM
djn's Avatar
djn
Thanks,
I'll pull it appart this afternoon and see if I can find the rip or crimp.
Appreciate the help..
Old Oct 13, 2003 | 02:13 PM
djn's Avatar
djn
Brad
You're right! The rubber under the elbow was crimpped and the edges around the hose clamp are ripped. I will need a new elbow. Any idea where I can get one cheep?
Old Oct 13, 2003 | 02:24 PM
ead94z28's Avatar
I think gmpartdirect has it for around 45.00 plus shipping, or you can go to your dealer and pay 60.00. Thats what I did. For the extra 10.00 it was worth getting it right away. Mine was FUBAR.
Old Oct 13, 2003 | 02:57 PM
djn's Avatar
djn
Thanks..
Old Oct 13, 2003 | 03:09 PM
anaik's Avatar
Get the 1LE elbow, same thing without the silencer, plus the rubber is thicker. I doubt you'll get one at the dealer for $60. Use one of the discounters, Dal or Jason. GMPD charges a fortune for shipping.
Old Oct 13, 2003 | 03:10 PM
ead94z28's Avatar
Sorry, I was referring to the 1le.
Old Oct 13, 2003 | 03:12 PM
anaik's Avatar
Their addresses and phone numbers are in this thread.
http://web.camaross.com/forums/showt...=Dal+and+Jason
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
beaver50
Feb 15, 2015 02:56 PM
LT14LIFE
Feb 9, 2015 09:35 PM
slothgrant
Aug 22, 2002 03:01 PM
