Help car will start then cut off help!!!!!!!!
Old Oct 13, 2003 | 06:51 PM
shootcallerz28's Avatar
I thought it was the Icm put a brand new on today.The car ran about 5 min then cut off it will start then cut off .The opti is 6 mouths old it was put on at the dealership.I put a brand new accel coil on. what is could be the problem help please thanks.
Old Oct 13, 2003 | 06:58 PM
InjectedSS's Avatar
So does the car actually start? Does it start, and then just die? Could be a vacum leak if that's the case.
Old Oct 13, 2003 | 07:05 PM
Unhappy
The car will crank sometime and run good i put the icm on and it start up good sit there and ran for 5 min and cut off. every time i try to start it it run for sec and then cut off.
Old Oct 13, 2003 | 07:42 PM
96cam4ro's Avatar
Sounds like the ignition module to me..it's located on the same bracket as the ignition coil.
Old Oct 13, 2003 | 07:57 PM
done put a ICM on .
cmdeshon
Dec 12, 2014 10:51 PM
Dec 4, 2014 11:56 AM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
BOOGER
Jul 25, 2002 02:42 PM
