won't go into reverse
Old Oct 12, 2003 | 09:27 PM
spencer95z28's Avatar
My car won't let me into reverse. All other gears are fine. completely blocked off to reverse. Whats wrong? I just eliminated skip shift by unplugging the solenoid and using a 2.2 resistor, but I didnt tape it or anything. I thought this was the problem so I plugged the solenoid back in. It didn't work though. I still can't shift into reverse. Any feedback would be appreciated
Old Oct 12, 2003 | 09:31 PM
got_hp?'s Avatar
the reverse lockout solenoid could be stuck......shoebox would probably know.
when mine wasnt functioning, but i could still get into reverse, it was just really hard to push in.
Old Oct 12, 2003 | 09:55 PM
yeah its been realy hard to push it into reverse for a while now. That could be the problem. Maybe it finally gave out.
Old Oct 12, 2003 | 11:01 PM
Randomsoleil's Avatar
have you recently installed a clutch..if so the flywheel could have ben shaved too much is you got it resurfaced. if not it could be a fw other things but check to make sure that your floor mat isnt keeping you from engaginf the clutch pedal all the way in.... this sounds funny but i took my car to three mechanics untill we figured out that it was the mat after i had gotten a new clutch and flywheel put in.....they needed to be replaced so that wasnt te reason
Old Oct 12, 2003 | 11:28 PM
Not a new clutch. Its at least 2 years old. How can I contact shoebox? Is it possible to replace the solenoid?
Old Oct 12, 2003 | 11:46 PM
it is but is a bitch to do it
Old Oct 13, 2003 | 05:05 PM
What do you mean? Is it time consming, costly, etc. ? How much would a dealer charge? Shoebox, I could use some advice, or anyone else, thanks guys.
blac94Z
Nov 4, 2015 01:59 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Hal Fisher
Sep 30, 2015 09:03 PM
KYWes
Sep 26, 2015 08:49 AM
Daluchman1974
Sep 11, 2015 06:12 AM
