95 Z Obd1
Old Oct 12, 2003 | 12:41 PM
streetrat129's Avatar
Question 95 Z Obd1
My 95 Z has obd 1 with an obd 2 connector and I want to know if antone knows what pins I use to jump so I can get the codeds. Also I have a scan tool fot each system but can't use either with this stupid connector that GM did this with. Please Help me if you can . Thanks Butch
Old Oct 12, 2003 | 12:43 PM
RamAir95TA's Avatar
You can only jump the pins on a 93 model to flash the codes. 94+ models can not be diagnosed this way. You'd need to have it scanned with a scan tool/software.
Old Oct 12, 2003 | 12:44 PM
Eddie95Z28's Avatar
You can't "jump" the pins of a 95, I think the last car you could do that with was a 93. Your best bet would probably be to get a cable and some free software like freescan.
EDIT: He beat me in.
Old Oct 12, 2003 | 12:49 PM
RamAir95TA's Avatar
To add to the complexity, you probably won't be able to have it scanned from Autozone, because they don't carry the 16-pin OBDI connector required to scan it. A dealer would be your best bet.
Old Oct 12, 2003 | 01:03 PM
obd 1 scan tool
can i in some way jump the pins between the connector and my obd1 scan tool I would like to diagnose this today
Old Oct 12, 2003 | 02:09 PM
Re: obd 1 scan tool
Connect your 12 pin OBD-I scan tool connector like this and it will work. (pins 5 and 9)
Old Oct 13, 2003 | 12:55 PM
Thank You Shoebox that was exactly whay I needed it showed the problem code 29, already have a air pump so thanks again. Butch
whitehooptie
Aug 10, 2015 07:02 AM
Pullngz
Jul 26, 2015 05:55 PM
88IROC_Z
Jul 22, 2015 11:38 PM
sfGi8nt
Mar 15, 2004 03:27 PM
T/A KID
Mar 12, 2003 03:37 PM
