Wheel sizes????i wanna go wide!!
Old Oct 13, 2003 | 07:40 PM
Cory1994z28's Avatar
Cool Wheel sizes????i wanna go wide!!
I have the stock salad shooter 16in rims on my z28, i am considering buying either 17 or 18in crager SS's or american racing torq thrust II's .... any opions on theses wheels... I want to get the widest tires possible. So how much biger can i go on the front and back . I know 17 or 18x 9.5 fits, but i want to get the widest tires on possible..... just give me a good idea of a good wheel and tire size set up... thanks.... stroker motor is on the way this spring and I don't want to be spinning
Old Oct 13, 2003 | 08:10 PM
pics
If anyone has pics of these wheels or others they recomend. please send pics thank you
Old Oct 13, 2003 | 08:49 PM
jchevy's Avatar
If you do a ZR1 replica you can go 17x9.5 in the front with a 285 tire and a 17x11 in the rear with a 315.
Old Oct 13, 2003 | 08:52 PM
Kataklysm's Avatar
I used to have 275 in the front and 315 in the rear...the 315 rubbed the inside of the wheel well on the drivers side, if you go thst big you might want to think about a spacer.
Old Oct 13, 2003 | 09:06 PM
Does the same go for the 18's... and what do you think about Goodyear F1 Gs-d3
Old Oct 13, 2003 | 09:09 PM
KCFormula's Avatar
I have 17x11s in the back of my lowered Formula and it doesn't rub at all, on the inside of the wheel well. (get an adj. panhard rod) It rubs on the top of the wheel wells because my car is so low and I haven't rolled my fenders yet.
BTW you can also fit 17x11s up front if you shave the knuckle off the top of the spindle.
Old Oct 13, 2003 | 09:10 PM
Fastbird93's Avatar
If it was rubbing on just the one side, could it possibly have been the rear not centered???
Old Oct 13, 2003 | 09:17 PM
as far as stright line proformance Vs. cornering do the 17 x 11's slow me down in the strights...pics of your lowered bird?????
Old Oct 13, 2003 | 09:20 PM
jchevy's Avatar
The big wide tires and wheels will slow you down if you dont have alot of mods. Im pretty sure the 17x9.5's all around slowed down my car.
Old Oct 13, 2003 | 09:23 PM
what tires are you running
Old Oct 13, 2003 | 09:26 PM
jchevy's Avatar
Im running 275/40/17 Kumho's
Old Oct 13, 2003 | 09:35 PM
anyone else felt this slow down.... what about 17 vs. 18's?????
Old Oct 13, 2003 | 09:59 PM
FRDEATR's Avatar
I have the 315" Nitto DR's in the back and the 275's up front. I have experienced no rubbing whatsoever and I did not have to modify anything. My car is also lowered. Hope this helps.
Brian
PICS IN THE SIG
HectorM52
Jul 30, 2017 11:46 AM
carguy0119
Apr 11, 2016 11:11 PM
ChrisFrez
Apr 5, 2015 05:54 PM
ChrisFrez
Nov 30, 2014 08:41 AM
JoshGuitar
Jul 23, 2002 06:20 PM
