what should i set my fuel pressure at?
Old Oct 13, 2003 | 08:46 AM
wayne97's Avatar
Next week my 383 will be in my car and here is what its gonna have...
heads flow about 280 @ 6000, comp XE 233/239 duration @ .050", .569"/.577" lift. The rest is what I have in my sig at the bottom. I was wondering if anyone had a similar setup and what fuel psi they were running. thanks
Old Oct 13, 2003 | 09:44 AM
IDOXLR8's Avatar
The best way to set fp is on a dyno. Also you want to monitor your car to make sure that you do not lean it out too much.
Old Oct 13, 2003 | 09:48 AM
If you already have MadZ28 programming, and it is for the engine you are building, you had to tell him your injector size and fuel pressure before he could do the programming. Typically, you will chose between 3bar (43.5psi) and 4bar (58psi), depending on the size of the injectors in relation to the flywheel HP you are making, and the type of injectors.
Old Oct 13, 2003 | 09:49 AM
wayne97's Avatar
what do you mean by lean it out? I'm not the most knowledgeable on here as you can see...
Old Oct 13, 2003 | 10:07 AM
wayne97's Avatar
he hasnt reprogrammed it from my hotcam yet. im probably going to use #30 SVO injectors,
Old Oct 13, 2003 | 10:21 AM
Then, if you have any idea what the estimated flywheel HP is going to be, I would set the fuel pressure so the 30# SVO's never see more than 80% duty cycle. MADz28 will know what that is. It won't be much different than stock.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
Nostang 96z
Sep 10, 2002 08:54 PM
