BIG CAM guys in here
Old Oct 14, 2003 | 02:13 AM
MBonZ28's Avatar
I am in the process of planning out a new motor (lt1) I need cam help. post up your cam specs along with heads, cubic inches, 1/4mi times and dyno numbers if ya got em. thanks!
Old Oct 14, 2003 | 02:15 AM
Kain's Avatar
See sig.
The real question is; how fast do you want to spin your motor?
Old Oct 14, 2003 | 02:18 AM
MBonZ28's Avatar
as high as I need too...I just want to make a ton of power. somewhere in the 3500-7k range
Old Oct 14, 2003 | 02:22 AM
Kain's Avatar
7K? Thats no biggy. With a good set of heads, ported AFR 190cc's or something, the CC306 could take you there, that or the XE236/242.
But if you want huge power, you'd probably want AFR 227cc's, or some other more elaborate and expensive heads. I'll let someone speak up with more head experience than I do.
Cam's I've got covered. Got any specific questions about cams?
Old Oct 14, 2003 | 04:46 AM
Jay-Roll's Avatar
Kain those are really good times for the mod's you listed. Are those the only mod's you have or just the major ones? I have very similar mod's to you accept a 3000rpm vig. and I don't have a cam yet. But if I can expect to see times like that if I run well I'm psyched.
Old Oct 14, 2003 | 05:19 AM
BES-383's Avatar
The question is, How fast do you want to spend? Depends on how much money you got.
Here are my cam specs . They were installed with 1.6 rockers. Motor stroked 383, stock casting max ported heads, with domed pistons. Compression is at 14:1. Dynod at 557 FWHP and 490 FT-PDS torque. Hope to get every thing wrapped up this week so I can get some track time. Should run high 10s N/A. Am sure I could have gotten alot more with some AFRs but wanted to see how far I could get with stock casting heads. Good luck in your quest for your new motor.
Old Oct 14, 2003 | 08:44 AM
ledfootz28's Avatar
i have some cam questions for ya kain.can u email me at ledfootz28@hotmail.com so i dont hi jack the thread?
Old Oct 14, 2003 | 09:55 AM
kmook's Avatar
Advanced Tech Moderator
230/236 112lsas xe cam, stock lt1 ported heads, stock bottom end, 406/375 STD on the dyno. 12.4@115
242/248 585/586 112lsa solid roller, stock lt1 ported heads, stock bottom end. no times or dyno #s.
Old Oct 14, 2003 | 10:33 AM
Grease's Avatar
GM847 cam (234/242, .539/.558 lift)
Advanced Induction "Econoport" heads
Stock bottom end with 78000 miles
412rwhp, 372rwtq
12.29 @ 115.98mph
further details in my sig
Old Oct 14, 2003 | 11:05 AM
got_hp?'s Avatar
grease.......youre running 1.5 rr's?...........with 1.6 that cam is 575/595 lift
Old Oct 14, 2003 | 11:21 AM
Kain's Avatar
Oh no, I've got the regular army of bolt-on's behind it. My Vig is really loose, normal Vig3200's flash about 3600, mine flashes 4000.
Cam picked me up alot. Before the cam I ran 12.9@104 w/ 1.77 60'. I was suprised it picked me up 7 tenths and 5 mph.
Old Oct 14, 2003 | 10:17 PM
Ai's Avatar
Ai
230deg int. duration - that ain't big
Seriously though.. "big" is a bit subjective IMO. I wouldn't sell street people anything larger than something like the 236/242ish lobes though (stock displacement) . Of course if you arent daily driving the car, and
want to focus more on performance than anything, you could go a little bigger without too many issues IMO
As far as Grease's stuff, I believe he's running 1.6RR's. His stuff was setup with them in mind anyway
Old Oct 14, 2003 | 10:42 PM
atljar's Avatar
Not huge here but VERY driveable
Same cam as grease, 350 cubes
Rest is in the signature. Just need traction now.
Old Oct 14, 2003 | 11:12 PM
spraytheway's Avatar
Comp Cams solid race roller
over 270 @ .50 int
over 280 @ .50 exh
over .700 lift both sides
LSA is narrower then you might think for Nitrious cam
AFR 220 race ported heads
big compression race gas only
with Nitrious over 800 rwhp
Times are in Sig...suffering from poor traction. I like my big cam
Vince
Old Oct 15, 2003 | 12:37 AM
Kain's Avatar
Originally posted by SkarodoM
230deg int. duration - that ain't big Seriously though.. "big" is a bit subjective IMO.
This is very true. If a person is running the stock bottom end, odds are they don't want to spin over 6500 and you can go too big.
But if you have a build SBC motor like my friend does in his 69 Firebird and rev's 9000 rpm, that takes a little different cam.
