Timing chain options.... (cam install)
Hi guys,
I'm getting ready to put in an 847 cam in my '93 (with a '94 engine) and was wondering about my options as far as the timing chain goes.
I definetely want something stronger, but would rather not upgrade to an electric waterpump. (I've had one before and even did all the LED/SWITCH wiring for it, but it failed the first week after the purchase and I really don't want another one)
I do not plan to rev the engine past 6300 rpm and the heads will be stock. (with upgraded components of course)
Thanks!
Thanks!
Since I wasn't going to spin that high with the CC306 (I shift at 6400), I threw a new stock chain on the stock sprockets and called it a day, cost me like $20 at AutoZone. But it is very important that you do go with a new timing chain because the old one is probably worn out.
I just put a GM stock replacement on mine. Im pretty sure that your only options with a stock waterpump and the 93/94 timing cover is either the stock replacement or a Lunati(dont know part number, do a search, there are some threads about it). If you want to upgrade to the vented opti and 95+ timing cover, it really opens up your options to the LT4 and the LT4 ED.
