93z dies please help !!
Old Oct 13, 2003 | 10:42 AM
jcolez28's Avatar
My Z died driving down the hwy. It restarted 15 min later, then drove 3 min and died again. After 4 times I had it towed to the mech. The car refused to die for him and drove fine for 2 wks. Then yesterday it did it again twice. Its not my daily driver but I cant even drive it becouse Im scared it will leave me stranded. The optispark is new and I replaced the fuel filter.It sounds like the fuel pump problem in my blazer. Thanks Buy the way when I attempt to restart after dies it turns over fine.
Old Oct 13, 2003 | 01:00 PM
streetrat129's Avatar
I had a similar problem twice, once it was only a bad coil wire the other time it was the MAF sensor, hope this helps.
Old Oct 13, 2003 | 01:23 PM
fredmr39's Avatar
fuel pressure
If you suspect fuel pump, run some tests on fuel pressure if eqipped to do so. If in need of a pump, there is a GP for the Walbro 255 pumps in the GP section for $99.99.
--Fred
Old Oct 13, 2003 | 02:17 PM
snake_skinner93's Avatar
Check the Coil and Coil Wire and the ICM (located right on top of coil)
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 01:46 PM
Bxlt1
Sep 29, 2015 03:18 PM
KYWes
Sep 26, 2015 08:49 AM
