Which wire for theft deterrent?
Old Oct 12, 2003 | 11:50 AM
kevmor99's Avatar
What's the best wire for a theft deterrent (I bypassed vats)? If I have a switch that opens a wire to the optispark (crank sensor?) will that keep the injectors from firing at all? Or should I use a wire that powers the fuel pump relay?
Old Oct 12, 2003 | 12:12 PM
If you open wiring that inputs to the pcm (like opti), you will get a code. Maybe better to do the FP relay. Shouldn't be any problems with that.
surreybrad
Apr 22, 2015 06:40 AM
EdgarArmada
Apr 18, 2015 05:20 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
kandied91z
Aug 6, 2002 01:18 AM
