Whole left side of car paralyzed?!
My definition of car paralysis..... This morning I noticed the whole left side of the car's electrical is just dead. From the front turn light to the back stop light - none works. I've checked the fuses and they all seem fine, this coupled with the ABS lights just stays on now after the cam install.I did noticed that the left side of the 3rd brake light have burned out and I thought thats what is causing all the issues so I have sinced replaced that and still nothing. Also, the front turn light when used will just give out a solid light as opposed to the blinker
??? What else could this be...????
Strange, but I would start by checking the large mulitple connector under the left side of the dash. While you are down there, you might also check the long connectors that are at the base of the steering column.
1996LT1Z28
Dec 4, 2014 09:20 PM
