Oil Pressure, engine shutdown?
Old Oct 14, 2003 | 12:03 PM
BUBBA's Avatar
Probably, many vehicles have a shutdown system when the oil pressure becomes dangerously low. Is there a good one for the Lt1?
If so, which one, and how does it work?
I don't believe one should be without one.JMHO
Old Oct 14, 2003 | 01:24 PM
GREGG 97Z's Avatar
I think I've heard about one that works off of the oil pressure sending unit. I don't have any info on it but I'm sure someone on here probably does.
Old Oct 14, 2003 | 02:12 PM
BUBBA's Avatar
Found one com'l jobbie that protects against low pressure, high coolant temp and low coolant level. Price around $200 for the works.
Another outfit said they would fabricate one for the Lt1, for low oil pressure, and sell it to us for between $80-$90.
Commercial system warns about the condition and shuts engine down in 30 sec. Obviously would be too late if you were racing, but it might save the crank, which is much more expensive than bearings.
The fabricated one would have a button which you would need to push when starting, but when the oil pressure dropped whould shut down the engine.
I don't know. Just thought I'd kick it around, since I lost an engine because of low pressure and I know there are more out there who would probably benefit from a shutdown system. Especiallly a simple inexpensive one.JMHO
Old Oct 14, 2003 | 03:27 PM
GREGG 97Z's Avatar
For $80-90 that sounds like pretty good insurance against a spun bearing. let us know how it works out if you go with one.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Jessie4tin
Jan 7, 2015 08:53 AM
jayblev95
Dec 1, 2014 06:55 AM
Jul 4, 2005 05:00 PM
