95+ cam in a 94 engine without opti conversion?
Old Oct 13, 2003 | 12:02 AM
madwolf's Avatar
Arrow 95+ cam in a 94 engine without opti conversion?
Possible without a lot of headaches?
IIRC, the difference is in pin height, but can I adjust/replace it without special equipment? The cam is an 847 and I want to put it in a 94 engine. I'd rather not do the opti conversion unless I have to. (don't have anything against the non-vented opti personally )
Thanks!
Old Oct 13, 2003 | 12:10 AM
Z95m6's Avatar
i don't think you can. I thought the unvented opti was run off splines on the shaft, the 95 cam won't have those splines. Maybe i am wrong that just what i thought i heard.
Old Oct 13, 2003 | 12:16 AM
madwolf's Avatar
Check out this webpage.... Quote "A late cam is compatible with an early optispark as long as the cam pin is installed at the correct height."
Old Oct 13, 2003 | 04:00 AM
RedPhenx's Avatar
the only difference i can tell (i have a 94 and 95) is the dowel pin length that goes into the opti... though I cant remember which one is longer.. i think the vented optis required longer dowel pin, though i could be wrong, but if im not, then all you need to do is grind a little off.
Old Oct 13, 2003 | 07:55 AM
Kyle@CSS's Avatar
I just built a 383 and I ordered a custom cam. They sent me a 95 up. All I did is grind down the pin. I also did this same thing with my 355.
Old Oct 13, 2003 | 08:05 AM
As already confirmed, it will work just like that. The splined drive is on the cam sprocket, not the cam.
Old Oct 13, 2003 | 10:09 AM
DansTransAM's Avatar
I wish i could get ahold of a LT4 Hot cam kit that would kit a 94
Old Oct 13, 2003 | 11:51 AM
PoorMan's Avatar
I think all LT1 cams have the longer pin. At least aftermarket ones. My XE 224/230 had the long pin and I just cut it to the length of my stock 94 cam using a dremel w/ a cutoff wheel. It's easy.
Jeff D.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
Injuneer
Dec 15, 2014 09:36 AM
