How to make a 52mm TB?
Old Oct 13, 2003 | 11:11 PM
AustinZ28's Avatar
Ok, does anyone have instructions to do this? My Dad own a machine shop and could easily bore my 48mm TB out to a 52mm. Instructions would be great and also where to be the new "fins" that go inside. Thanks in adavance-------------> Brad
Old Oct 14, 2003 | 08:38 PM
AustinZ28's Avatar
Has anyone done this? ---------------> Brad
Old Oct 14, 2003 | 09:40 PM
AustinZ28's Avatar
Come on ---- has anyone done this? Or should I just buy one? Wanted to save some money for more important things.-----> Brad
Old Oct 14, 2003 | 09:45 PM
Compstall's Avatar
Hey, if your Dad has his own machine shop he should be able to figure out how to bore it out. You've got it easy with all the equipment available.
As far as I know, all that's needed is the overbore (of course), then fabbing up some throttle blades that will fit. Make them identical to the factory blades, just a hair larger.
Old Oct 14, 2003 | 09:49 PM
AustinZ28's Avatar
Sounds like a plan, thanks for responding. I guess I was wondering mostly about fabricating new fins for it or if anyone sold tb fins just to make the job easier. Anybody know if 52mm is the most I can bore it out to or can I go larger? Thanks again ----> Brad
Old Oct 14, 2003 | 10:08 PM
Compstall's Avatar
Maybe Shoebox or someone "in the know" will pipe in here, but I THINK you have to work out some minor details if going any larger on a stock TB.
Old Oct 14, 2003 | 10:45 PM
atljar's Avatar
search for user NOMAD . He bores them out and sells them. If anyone knows, he does, but i dont know if he will want to tell his tricks.
NOMAD's Avatar
Cool
52 is the biggest you can go without moving the bores inward. You can buy the blades pre cut from me 10 at a time at $15 each.
Good luck, it's alot more complicated to get a good throttle body without some serious R&D. I'll give ya a hand shake if you can figure out how to get it apart without cutting the shaft or anything on it
I spent a few hundred bucks on 5 throttle bodie before I ever got the flow I wanted and the blade tip in, etc perfect. Thats why mine f'ing rock Lol
-Shannon
Old Oct 14, 2003 | 10:47 PM
NOMAD's Avatar
Cool
Wheres my track times !!!! Lol
Check out nkyfba.com cruise portion of the board. I think i'm gonna try to get to the track next weekend I fi can locate some slicks
-Shannon
Old Oct 14, 2003 | 11:01 PM
atljar's Avatar
I SWEAR that the car hasnt had a day at the track with more than 2 runs on it. I'm shooting for the 25th of october at tri-state. Im off work that night, so should be a good day to abuse the car and get plenty of runs in, both with and without the TB. I did make 357rwhp with stock heads and your TB, is that worth anything???
Old Oct 14, 2003 | 11:44 PM
NOMAD's Avatar
It's worth something I guess :P
I'm shooting for the same date, So i'll prolly see ya there
-Shannon
Old Oct 15, 2003 | 12:31 AM
fireman's Avatar
I took mine to a local machine shop, explained what I wanted done, and he did it. Cost for taking it apart, boring it out, puting it back together, and installing the blades I provided him-$100
Blades cost me $24(pair) from Arizona Speed & Marine.
Total cost-$124.
The guy had never bored out a throttle body before and it came out perfect.
BTW-$15 a blade!, 10 at a time! Wow.
Old Oct 15, 2003 | 09:10 AM
NOMAD's Avatar
Cool
Gotta pay for the good stuff. These put everyones elses to shame, just ask Atljar
-Shannon
Old Oct 15, 2003 | 11:47 AM
atljar's Avatar
Shannon knows im really happy with the TB. The bores are straight and smooth, blades are tight but dont stick. Speaking of the blades, the things he uses are SUPER thin. I would assume that splits the air cleaner and allows a tad more CFM to pass through. I know i used a BBK 58mm on a 383 i built, and the blades were much thicker. hope that helps a little.
Old Oct 15, 2003 | 12:04 PM
RallyRed701/2's Avatar
just curious... nomad, how much do you charge for your bored out tb's???
