Tire Size for my '97 Camaro SS
Old Oct 13, 2003 | 09:55 AM
vahman's Avatar
I am looking to replace my current "really really bald" tires with GoodYear Eagle F1 GS-D3's. Unfortunately, the exact tire size for my car (275/40-17) is on backorder for a minimun of 8 weeks. I was wondering if anyone has put or knows if you can put 285/40-17 size tires on this size rim without any issues.
Thanks.
Old Oct 13, 2003 | 10:01 AM
Don 97 SS's Avatar
Yes, I have had Michelien 285's on my car for about two years. They fit just fine and there is no indication of any contact in the wheel well.
Old Oct 13, 2003 | 01:45 PM
stereomandan's Avatar
Should be fine, but your speedometer will be off slightly. You will be going slightly faster than what your speedometer reads.
Dan
Old Oct 13, 2003 | 01:47 PM
Seal's Avatar
with a diff of 10mm the speed diff will be less than 1mph
Old Oct 13, 2003 | 01:58 PM
Just wanted him to know, that's all.
The higher in speed, the higher the difference in MPH, but you're right, the difference is not large.
Dan
Old Oct 13, 2003 | 02:02 PM
vahman's Avatar
Thank you all for your help. I just ordered the tires.....can't wait for another 2 days so I can put them on.
Old Oct 13, 2003 | 02:48 PM
1996 | Z28 SS's Avatar
Wait... what does the width of the tire have to do with the speedometer? It's the diameter of the wheel plus the sidewall hight is it not? With 285 vs 275 his speedometer should read the exact same. I mean if you put bicycle wheels and tires on that still have the same overall diameter (outside dia. of wheel plus sidewall hight of tire) it would still do one full rotation in the same amount of time correct? Maybe I'm just full of it.
Trevor
Old Oct 13, 2003 | 02:55 PM
dnz28's Avatar
No okay say you bought a set of 275/45/16 alright then you bought another set 285/45/16. Got it so far the 275 stands for diameter and the 45 stands for the aspect ratio wich means its width is 45% of the diameter of the tire. gots it
Old Oct 13, 2003 | 03:15 PM
anaik's Avatar
The 285 is about .3" taller, no big thing.
Old Oct 14, 2003 | 03:56 PM
fdxpilot's Avatar
Originally posted by 1996 | Z28 SS
Wait... what does the width of the tire have to do with the speedometer? ... Maybe I'm just full of it.
Trevor
No, just a little confused. The 285 is the width, but the 40 is a percentage (or aspect ratio, to be technical), so the sidewall height is .4 x 285. So a 285/40 would have a sidewall height of 114mm and a 275/40 would be 110mm. Therefore, the 285 will be 8mm more in diameter, or about .3in. Thats what will cause him to read slightly below his actual speed. For an example, look at a stock C5 vette. bothe tires have almost identical sidewall height, even though the front is 245/45-17 and rear is 275/40-18. Hope this helps.
Old Oct 14, 2003 | 05:37 PM
sean1997ws6's Avatar
I have seen a 1996 ws6 with 315's on them. fit with no problems. If you want a good bang for your buck tire, get the Kuhmos off of tire rack, not the best but for 107 bucks what the hell.
Old Oct 14, 2003 | 05:58 PM
Ohh, right right. Forgot that the 40 was a % duh
Old Oct 14, 2003 | 06:14 PM
Tires_Smokin's Avatar
Has anyone tried putting 18's in the rear and keep the 17 x 9.5's in the front. I was thinking about putting 18 x 10 or 11's in the rear to fill up the wheel well. So what do you guys think?
ChrisFrez
Jan 4, 2015 08:43 AM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
ChrisFrez
Dec 7, 2014 06:01 PM
ChrisFrez
Nov 23, 2014 10:33 AM
