what tranny line goes where?
Old Oct 13, 2003 | 04:20 PM
dkeers's Avatar
There are 2 cooling lines off of my A4 transmission and 2 spots for them on the radiator. I just put in a new radiator and transmission (and many other things) and I don't know which line goes where. Or does it even matter?
Also, does anyone have a part number for the lines, or should I just get 2 braided lines made?
Dustin
Old Oct 13, 2003 | 05:08 PM
S.J.S.'s Avatar
That's a good question. Did you forget or something when you took it apart? Gotta put my motor back together soon so I would like to know this too.
Old Oct 13, 2003 | 07:02 PM
dkeers's Avatar
I don't think it should matter. Either way tranny fluid will pump through the radiator and then back to the tranny. I just want someone to tell me for sure.
Dustin
Old Oct 14, 2003 | 10:15 AM
stew's94z's Avatar
The bottom line feeds the cooler and the top line returns to the trans.
Dean Stewart
Old Oct 14, 2003 | 02:16 PM
revtime's Avatar
Yep top line is return line.
Old Oct 23, 2003 | 01:45 AM
S.J.S.'s Avatar
Like for me...the lines are completely off. Which hole on the trans is the return hole????
Old Oct 23, 2003 | 06:53 PM
$hawn's Avatar
The line on the bottom goes to the fitting at the bottom of the radiator, and the top line, the one with the end is rubber goes to the top.
Old Oct 23, 2003 | 11:50 PM
stew's94z's Avatar
The top line or return line goes in the top hole on the trans.
Dean Stewart
Old Oct 24, 2003 | 02:00 AM
S.J.S.'s Avatar
thanks guys. Always better to be sure.
BigWil
Mar 29, 2015 12:24 PM
jackpawt883
Feb 26, 2015 09:04 PM
737drivr
Feb 20, 2015 11:54 AM
