Why does the same ARP header bolt loosen up??
Old Oct 12, 2003 | 01:17 AM
JuiSSed's Avatar
lost another header bolt today coming home from SLP day at e-town... it's the same one.. last one on the passenger side... lock washer didnt help.. i've re-tighten it over and over.. it's not striped, cause when i make it tight, it's tight..the first to last bolt on the same header tube is almost on it's way out... anyone else experience this? all the other bolts are tight and never leak.. can i use lock-tite with alum. heads? i have GTP stage II heads and would hate to ruin them with the lock-tite..
thanks
vinnie
Old Oct 12, 2003 | 04:31 AM
anaik's Avatar
Are you using the 3/4" or 1" bolts? If the 3/4", maybe a 1" will hold better, having more threads in contact.
Old Oct 12, 2003 | 05:37 PM
JuiSSed's Avatar
i'm using 3/4" ARP bolt... i went to the local speed shop.. they only had 3/4" or 1 1/2".. would 1 1/2" be too long?
thanks
vinnie
Old Oct 12, 2003 | 05:49 PM
Z95m6's Avatar
why not just buy some stage 8 locking header bolts?
Old Oct 12, 2003 | 05:52 PM
JuiSSed's Avatar
i'm going to go with the STAGE 8 route, but i was just curious why the same bolt lossens up... why no the other ones?
thanks
vinnie
Old Oct 12, 2003 | 06:07 PM
idunno's Avatar
it has to do with the reverse cooling. because of the way the coolant flows through the heads, that paticular bolt has the most thermal stress on it, so it loosens up easier than the rest...i have to tighten mine every 2 weeks
Old Oct 12, 2003 | 06:11 PM
JuiSSed's Avatar
thanks for the feedback..
vinnie
Old Oct 12, 2003 | 07:41 PM
That same bolt came loose once on my stock manifold. <shrug> Apparently, it is a problem child.
Old Oct 12, 2003 | 07:43 PM
LeathernecK's Avatar
I've always had the same problem with that bolt.
Old Oct 12, 2003 | 08:02 PM
ibanez6rg's Avatar
I'd just buy it in 1" form and see if that fixes the problem.
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Catmaigne
Dec 25, 2014 12:16 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
