Car running hot, low coolant light and coolant smell inside car, what do I do now?
Well sounds like a busted heater core to me. Low coolant light came on today after I changed the thermostat and topped off/bled coolant last night. Car began running warmer, up to 215* and the low coolant light came on. Next I notice a faint coolant smell in the cabin. I could have sworn it was coming through the vents. Also when I turned on the vent and turned the fan on high I got some condensation forming on the inside of my windsheild right about the defroster vent
Alright guys, tell me what to do now
Any online guides for checking heater cores? removal/installation? Help me get this turd back running right again!
John <--- just glad it's not a blown headgasket
Any online guides for checking heater cores? removal/installation? Help me get this turd back running right again!John <--- just glad it's not a blown headgasket
New info, need some help here.......... My brother hooked up a pressurizer pump to the radiator to put the cooling system under pressure. We pumped it up to 18psi and it held it.... Did not leak at all. How can I track down a leak if I can't find it?
Could also be that you may have an air pocket some where. Even if you pressurize the system if the air pocket moves you will get a different reading. Did you get coolant coming out of the bleed off screws on the two hose on the front. Sound to me like that. If your heater core was leaking the passenger floor would be wet and smell like antifreeze.
Well, heater core was leaking. The insulation under the carpet was damp and the plastic cover that goes around the heater core had some coolant in it. However, I don't think that there is enough coolant leaked out to be the cause of my problem
Basically, I'll add about half a gallon of water to the cooling system, and then a day and a half later, it's back to the low coolant light coming on and the car running hot. If that much was coming out of the heater core the floor would be drenched. It also appears that my radiator cap isn't doing it's job. Even when the coolant level gets low it doesn't pull any coolant from the overflow tank. The level stays the same.
Also, I do bleed the system every time I top it off. I get about two seconds of air, then some bubbles and then a steady stream of coolant.
Damn this sucks!!
Damn this sucks!!
when there is a leak it is no longer a sealed system, meaning it loses pressure, and/or vacume. it may not pull water in from the overflow.
also, the overflow is for when it gets hot, water expands and ries to boil, builds pressure and fille the overflow. if there is a leak it wont hold the vacume to suck it back in. it will just suck air from the hole. also couse the car to run hot becouse lowere pressure in the system water boils faster and vapor dont cool engins.
Originally posted by shoebox
If you have any coolant inside the core cover, replace the heater core. If you don't you are just asking for more trouble.
Originally posted by lbrowne
is it right behind the glovebox like I asked?
John
fpete1992
Dec 11, 2014 03:51 PM
ro2207
Dec 4, 2014 06:18 PM
