water pump
Old Oct 13, 2003 | 06:16 PM
PolivickRS's Avatar
water pump
1993 LT1 '92 Camaro. Wondering how you can tell if the water pump is bad. Engine gets hot and I have some leaking of coolant in the passenger side inside the car. Seems like the water isn't moving though because there is no heat coming out of the heater. Any help would be great.
Old Oct 13, 2003 | 06:39 PM
InjectedSS's Avatar
Check underneath the waterpump, there's a little hole called the weephole that will leak water once the seal start's to go bad.
Also check the thermostat which can cause the symptons your describing.
Old Oct 13, 2003 | 06:44 PM
revtime's Avatar
If you have coolant leaking inside the car then your heater core is bad and needs replaced.
It may be clogged so I would replace it and then go from there.
Old Oct 13, 2003 | 06:58 PM
Z95m6's Avatar
ditto sounds like the heater core.
HectorM52
Jul 30, 2017 11:46 AM
Biggiebound
Apr 21, 2015 11:28 PM
KYWes
Apr 15, 2015 07:28 PM
Blood type Z28
Apr 8, 2015 11:34 PM
pologreen97z
Dec 2, 2014 10:42 AM
