View Full Version : LT1 Based Engine Tech
- I want street legal true duals!
- Oil pump.... grrr!
- HELP! LT1 - M6 Transmission removal.
- Hotcammed cars that have been tuned, whats your FP?
- Street Twin bolt torque specs
- A couple of questions
- Took the oil pump housing off to prime pump, What do I torque the 4 Bolts to?
- gear drives w/ electric WP??
- Pulled the alternator, can I bridge the wires?
- will a 97 ABS unit work in a 94?
- O2 sensors.....Exhaust
- Answer to fuel smell in morning
- Need a GOOD replacement rack&pinion
- 94 Z28 Suspension upgrade tips
- Scan tool
- 94 LT1 Cooling system diagram
- hurst
- Paint color for gauge pod
- calling shoebox
- Help me out! Which mods should I do next?
- What Exhaust- Stock Tips
- Air Bags in - 0 weather
- 94 T56 to 97 4L60E wiring changes
- anyone tried an Oil flush???
- Head replacement question.
- Where can I buy used 93-97 firebird/ta parts?
- Installing new rear end???
- Exhaust installation
- calling all NITTO 555R > ONLY STREET < owners
- Accessory Bracket Question!
- CC306 is a blower cam??
- Headers: Longtubes or shorties?
- wierd whistling/howling sound from rear end. HELP ME!!
- Why won't my Z start? (362kb sound clip included!)
- Once again another header question
- What is involved in changing out the K-member?
- Belt # for March Crank/Alt pulleys
- 1LE A/C delete pulley?
- Just had the caliper totally seperate from the spindle just now.
- Usefullness of a 160 degree thermostat
- good choice for exhaust?
- LT1 rebuild
- Opti & Coil
- First Biggest Mistake with T/A - Warning Inside!!
- Dyno max Bullet mufflers?
- Power steering felp!
- LT4 hotcam for stock 96 WS6? Good Deal?
- XE 224/230 vs. 230/236, stock bottom end: how does YOUR car perform?
- MSD Coil questions
- Transmission coolers
- 94K clutch
- How much HP/TQ is your 383 producing?
- Anything to gain going from a 52mmTB to a 58mmTB?
- Belt Size Needed
- Which wiper blades?
- 3.4L/LT1 swap done, help with rear end?
- Is this the governor on a 700R4 trans? Picture inside!
- 12 bolt users got a ???
- Every Damn Day!!! Ses Light!@$!@#$
- Slight blue plug glow at night; normal?
- Walbro in-tank pump install how many people have reused the factory fuel bucket??
- T56 shifter????????
- Filler tube filter?
- How to put viton valve seals on
- how to tell the year of an lt1
- Slight coolant leak, but only in extreme cold
- Need Some suggestipns..ASAP
- Any way to check a bad opti?
- Lt4 Km?
- Going from 4.10 to 3.73?
- would this work?
- 1.6 RR's and Springs...
- hotcam sound clips..
- Holy Crapola!!
- oil leak
- Buying some sfc's does brand name matter?
- Moser 12 Bolt warning!
- Car Is Not Getting Spark
- the daze of our lives
- headers and straight pipes!
- AFPR on a 93?
- o2 problems
- Bored w/ my LT1...
- Need p/ns for radiator hoses
- Pulleys?
- B&M Shift plus electronic shift improver
- this us NUTS
- Heads/cam 350 C.I. LT1 people, post your dyno numbers please
- hotcam installed
- which o-rings with 30ib svo's?
- Cags
- Service Engine Soon
- Comp Cams XE part #
- Hypertech Programmer
- Coil?!?
- Wierd Ignition Problems
- headlight motor ?
- Has anyone tried to filter the oil mist going into the intake manifold?
- Tranmission problem
- Estimated ET?
- Dyno Tuning-New Shop
- Somebody answer quick please
- Anyone In San Jose California!!!!
- Which headers
- Tranny slippage in 2nd only?
- Anybody runnin off road Y?
- Cc305
- y pipe
- PROBLEMS need help within ASAP!!!
- Will I Gain More HP With New Injectors IF...
- Windshield Wipers
- New cam
- trans ams with lowering springs
- How do you remove our windshield wiper blades??
- tranny dilemma
- Another valvetrain question!!!
- Hydra-Rev HP gains?
- geen stripe injectors
- Great fender roller...
- Votmeter is on LOW! What is the problem?
- Summit is cool...
- edelbrock shorties and stock y-pipe
- Stressed Metal sound from brakes
- Random Tech 92400 Converters on '97 LT1
- Rear susp clunks when making slw turns
- Longtube Boys Inside
- Rate cam/springs/rockers install on scale of 1-10.
- How to put viton seals on
- how much does the stock exhaust weigh??
- CD changer with 95' bose
- can someone assist me in finding all differences in f-body lt1 vs impala/caprice LT1?
- Anybody With A 93 Ta/z28 Please Help!!!
- Signs Of Water pump going out?
- How do I know if I have a 4 or 5 prong connector on my transmission (700r4) ? help!
- LT1 in a Jeep
- Question on fuel cap/fuel tank...
- Suggestions????anyone????
- Speedometer on Gear Change?
- Guess hp/tq gains
- worst luck ever... please read... LONG
- Help! Dyno Graph inside...high rev miss?
- Help me make a shopping list...I know nothing of modding LT1s...
- Ractive Seats and PWR Seat
- Anyone ever use two donuts as skinnies for racing???
- Flushing Coolant
- Did The Fan Mod!!! BUT, Have A Q??????
- Have you ever had the fuel tank cleaned...
- Coolant dirty!
- replacing rear main seal
- 75K Maintenance
- Help, Car Running, Surging other Problems
- How hard is it to port LT1 heads to outflow LT4 heads?
- Corbeau Seat Install Questions
- Harlan Shift Light
- HELP Someone Good WIth Codes
- LT1 cam suggestions
- Need Exhaust Advice!
- Are these emissions legal?
- Stupid Cooling Fans!!! @#$%&*!!!!!
- Tercell losing 2quarts of oil a week , but no oil leaks ?
- Aftermarket LT1/LT4 heads
- Need CC306 TunerCats file!!!!
- LT1 Edit!!!
- Where to hook up chain when pulling motor?
- ok what is the best way for performance from ur LT1?
- what is the strongest yr for the LT1's
- question
- help with plugs & wires
- Good opti- Bad waterpump. How to change waterpump and not kill opti?
- hooker shorty headers
- Driveshaft question
- School me on the MAP sensor?
- need bulb part number please
- Question on rotating tires with front different from back.
- SLP loudmouth install???tips, hints, pics?
- How much RWHP can a Vigilante stall hold?
- Topspeed 95z28
- Brake pedal hits a "sticking" point with hard braking PLEASE HELP
- 7.625" Pos!!!
- coilovers?
- who has a tubular k member?
- What did you use to plug your WPdrive hole on timing cover?
- Mayday!!!!,mayday!!!!!
- anyone running a B&M torque converter?
- Question about the Delco bose.
- how much for trans installation?
- what does Torque converter do??
- What plug wires are you guys using?
- Is the CC306 to big for an A4?
- anyone make their own short throw?
- Cutouts on the Z
- went to tirerack.com...OMG help me...
- guys with TCI converters
- Question about checking oil...
- install help.
- CC306 help please
- Brakes, Compression, and some other stuff
- Battery relocation pictures
- HELP!! ZR1 wheels won't fit '94 T/A
- Comp Cams Pro Mag RR
- What's the size of the collector on SLP shorties
- Anyone using Competiton Engineering Rear Shocks?
- What size bolts for shifter install??
- need part numbers
- Does anyone rent out engine cranes?
- Noticing a lot of you are doing 383's, 396 and 355's - good info
- lt4 spring question
- Best headers that don't restrict ground clearance?
- Top speed governor?
- Which tires are best on snow/rain for 94Z?
- People with the XE 224/230 come inside
- Torque Arm ???
- Help
- Is it possible rear swap
- Torque Arm ???
- How to launch my car
- Opti blaming is anoying
- Best street tires?
- where did you guys buy your new rear?
- Is it ok to mount tires "this side in" out?
- where to get throwout bearing for cheap.
- How Do I Get To My Fog Lights?
- lowering springs....f-body vs. mustang
- SCREACHING noise coming from suspension!
- Hot Cam questions
- slight hesitation at 40+ MPH
- Two Diff. Questions In One Topic (Fogs/Tires) Please Help!
- Very Slight 'crunch' during hard acceleration (A4)
- LT4 Problem
- 97 Z28 uses which kind of antifreeze??
- Functional spoilers for the strip?
- Catback
- I Hate GM's designers
- thermostat question
- how hard is it to wire water temp and oil press. guages on the a pillar
- Low Traction gauge??
- Car Died
- Manuel Tranny Fluid Flush
- **FREE SAMPLES** New valve springs, no machining required
- Opti to Coil pack conversion.
- 1994 Lt1
- EGR removal lessen intake oil leak?
- Aftermarket fuel tank and pump
- At what point are larger injectors a good idea?
- Thermostat Part # (AutoZone)
- Biggest tires?
- Kenny Brown Roll Cage?
- ABS delete(prop. valve)
- will this engine fit on a 94 F-bodies??
- 94-95 Style headers? What size plug for ! AIR
