headlight motor ?
Old Jan 30, 2003 | 09:10 PM
speedcrazy's Avatar
headlight motor ?
on my T/A on one of the motors there is a plastic piece that covers the gear inside and i can't get that plastic case over the gear to stay on which basically holds the gear in there tight. i tried epoxy 2 different times and after u flip the light up and down a few times the epoxy just cracks and comes apart and the plastic piece starts comming off. is there anything that will hold that on there for good. something stronger than epoxy.
Old Jan 30, 2003 | 09:38 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
J&B weld....
Old Aug 10, 2003 | 05:26 PM
MMESSIER's Avatar
I have the same problem. Performed the metal gear install twice so far , both times the cover came off immediately. Will try a 3rd time using J&B Weld.
Old Aug 10, 2003 | 05:47 PM
craigffb's Avatar
Yep, JB weld will work. That's what I use after the epoxy broke. Just be sure to let it set up before you try using the lights.
Old Aug 11, 2003 | 03:53 PM
MMESSIER's Avatar
J-B Weld
Old Aug 11, 2003 | 10:41 PM
xchief1320's Avatar
i used 2 zipties in a criss-cross fashion..lol..works like a champ
Steve
Old Aug 11, 2003 | 10:51 PM
MMESSIER's Avatar
I used 3 ty-wraps after the J-B Weld cured. I wasn't about to experience another failure
Old Aug 11, 2003 | 11:11 PM
EviLZ28's Avatar
I used Duramix and it held great.
ChrisFrez
Feb 15, 2015 08:12 AM
94Z28LS1toLT1
Feb 10, 2015 10:19 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
CaRParts102
Dec 6, 2014 08:45 AM
