Comp Cams Pro Mag RR
Old Jan 29, 2003 | 10:54 PM
96BlkZ28's Avatar
Seeing how LT1's are center bolt heads you have to use SA RR on them. Im a bit confused about the fact that people say they have the Pro Mags on there car but all I see in Summit that they are no SA RR. Do you guys put on push rod guide plates? I ask this because im building another motor that is going to use the center bolt Vortec heads. I have an article that use the Comp Cams Mag RR which are SA but are made of steel I think. Well and pic's and info an how to put Pro mags on will help. Like modding the valve covers to fit them and stuff.
thanks
Old Jan 29, 2003 | 11:04 PM
Rodrigues's Avatar
You can you non self aligning rockers with guideplates I believe. I bought SA myself.
Old Jan 29, 2003 | 11:06 PM
atljar's Avatar
You can use non SA RR on the lt1 engine. Guideplates and hardened pushrods are a must. Some people have had the center support for the valve cover hit, but simply have notched it and had no more clearance problems.
Old Jan 30, 2003 | 12:14 AM
dobe's Avatar
I used Non SA cc 1.6 rr on mine with Moroso guideplates I have a 94 and they have hardened pushrods so I was able to reuse stock pushrods. Make sure you have hardened pushrods or better.
Old Feb 4, 2003 | 08:07 PM
Frank95z's Avatar
What years have the hardened pushrods?
Old Feb 4, 2003 | 08:30 PM
AZ2ENVY's Avatar
93-95 LT1's
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
MadMav
May 25, 2015 09:35 PM
carl.froehlich
Mar 13, 2015 12:38 AM
alliance12364
Mar 6, 2015 04:39 PM
