EGR removal lessen intake oil leak?
Old Jan 29, 2003 | 04:59 PM
wiked95ta's Avatar
Will the EGR delete help the rear intake oil leak problem?? Seeing as the EGR gets hot being connected to the exhaust, if you remove the pipe/disable it, will that help the problem from the intake dropping oil when getting hot? It's been to dang cold to !EGR and see if it works, just wanted to see if anyone has done this and found the intake oil leak kinda subsides..
Old Jan 29, 2003 | 07:21 PM
Patman's Avatar
If you relocate the EGR tube, or heat wrap it, I've heard this also helps keep the intake from future leakage.
Old Jan 30, 2003 | 11:22 AM
wiked95ta's Avatar
Great!! Thanks!!!
Old Jan 30, 2003 | 11:33 AM
Yes, some people claim the original cause of the oil leak is due to the EGR supply tube being too close to the intake manifold and overheating the sealant, causing it to break down over time.
HectorM52
Jul 30, 2017 11:46 AM
artic94
Jan 17, 2015 11:19 AM
Jul 4, 2005 05:00 PM
96z
Sep 5, 2002 07:53 PM
TrouserSnake
Aug 7, 2002 12:43 PM
