Manuel Tranny Fluid Flush
Old Jan 29, 2003 | 05:52 PM
ChewyChevy's Avatar
Tranny has 120k and it's time to change the fluid. I have the Dexron II/III AT fluid ready. My main question is, if there's a flush for manual tranny's and if I should flush the tranny. I noticed Sea Foam sells a flush for Automatic's but not Manuels.
Alex
Old Jan 29, 2003 | 06:18 PM
94z28jbw's Avatar
Thumbs up Hmmm...
I don't know what you mean by flush..? But, on 6-speed 4th Gen. F-bodies, there is a fill plug and drain plug, both on different parts of the tranny, easy to find. The drain plug is on the side, the fill is more near the top. Be ready when you pull that drain plug, it will shoot a couple of feet to the side. Checkout http://www.projecttransam.com or shoebox's fix-it sections and you'll find info. Also, on the main page of my website, you can DL a .PDF Complete Manual for the T-56 Borg-Warner 6-Speed Manual Transmission [93-02] . HTH.
Old Jan 29, 2003 | 07:23 PM
zman_virg's Avatar
Just drain the tranny and refill with Dextron III.
Old Jan 29, 2003 | 08:10 PM
95 Z/28 LT1's Avatar
Super Moderator
There's magnets in the bottom of the case, so whatever is in there probably isn't going anywhere until the tranny comes apart.
Old Jan 30, 2003 | 12:18 AM
94z28jbw's Avatar
Yep...
There's also a magnet in the differential. They are there to collect the metal flakes as the gears wear. Bolts are what actually fasten everything together in the tranny.
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
