97 Z28 uses which kind of antifreeze??
Old Jan 29, 2003 | 07:14 PM
Cool ZR's Avatar
Hello, I have bought a 1997 Camaro Z28 from Arizona, and I am getting it ready to be shipped. My question is wether or not the car uses the newer Dex Cool or the regular green antifreeze? I need to have the fluid changed before I ship the car to prevent it from freezing during transit.
If anyone knows which fluid it uses, I would greatly appreciate the info.
Cool ZR
Old Jan 29, 2003 | 07:17 PM
TheHeadFL's Avatar
Either one as long as its not mixed. I currently run green with no problems.
DexCool would have been the factory coolant. Chances are the previous owner was still using it.
Old Jan 29, 2003 | 07:18 PM
zman_virg's Avatar
It uses Dex Cool (the orange one). Make sure you add the antifreeze you start the car and open the two air bleed screws to purge all the system. It might later on need to be topped off.
Old Jan 29, 2003 | 07:22 PM
Cool ZR's Avatar
Cool, thanks guys, I will have to check with the used car dealer, hopefully the tech they use is competent and didn't just drop the orange and put the green back in b/c its cheap!!
If it is incorrectly bled, and it's driven say maybe a half mile total before I can physically check it myself, will it cause any damage? They will be driving the car onto the trailer, back off, and I will do the same into my enclosed and probably back off so Customs can inspect it
Cool ZR
F'n1996Z28SS
Aug 23, 2023 11:19 PM
cmdeshon
Dec 27, 2014 10:06 AM
MJ_Z28
Aug 7, 2002 07:15 PM
CobraEatr
Jul 22, 2002 09:49 AM
