went to tirerack.com...OMG help me...
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
k i put in all my info at tirerack.com and it says stock equipment - 235's optional stock equipment - 245's.... i KNOW i have the stock 5 straight spoke rims... but what size are they? cause the itres i have on now are VR 255's... 50 16.... ummm? what do i do?
235/55/16 is standard
245/50/16 was the optional speed rated tire
Your rim size is 16x8
The tire you have on your car now should fit without a problem. So you can replace it with the exact same tire (255/50/16. I'd stick to the 245/50/16 on the stock rim though. Get yourself some Kuhmo Ecsta tires, they seem to be a great tire for the price. Anything will fit and work properly with your speedo though as long as its 255 or 245/50/16
the 255's have 20 grand on em and they are working fine... and i want the widest tire possible... can't i just stick with 255?
we can't be talking about the same thing cause my rims are the stock ones and i have a 95... with straight 5 spoke alum. rims... with the abs cap in the middle....
We were arguing about Z28 wheels for some reason... our bad.
