Rear susp clunks when making slw turns
I've notice that some times while making slow turns the whole rear of my car kinda vibrates,would this be a differencial issue or something about the suspencion? I do know that there's a leak from the seal that always goes bad (betwen shatf an diff) but the clunk only happens during low speed turns.
thanks for any inputs.
If I were you guys I would change the rear-end lube and put some GM brand limited slip additive in it. Then see how it acts.
The additive is a friction modifier, and is supposed to let the clutchs in the carrier slip easier around corners, because thats when the rear-end unlocks. (You know, one wheel turns slower than the other).
Anyways, the clutches will last longer with the additive, so it's a good and cheap way of seeing if the carrier is going bad.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
