Accessory Bracket Question!
Old Jan 31, 2003 | 03:11 PM
TransAm SR71's Avatar
Has anyone ever relocated the alternator to where the A/C Compressor sits? I have deleted my A/C Compressor with the pulley that GM sells, but I would like to relocate the Alternator to the A/C Compressor position. How do i do it and what do i do about the direction that the Power Steering pump is turning?
ANY help would be appreciated! Thanks.
Old Jan 31, 2003 | 04:00 PM
Gripenfelter's Avatar
Why are you trying to do that?
Old Jan 31, 2003 | 04:22 PM
speedmiser's Avatar
Yes, but with the ones currently out, you have to ditch the Power steering.
One of the guys one this board is trying to design one that keeps the power steering though.
You might try checking with him periodically.
He're a link to an earlier post.
http://web.camaross.com/forums/showt...cation+bracket
Old Jan 31, 2003 | 04:25 PM
speedmiser's Avatar
You can run tall (undimpled) valve covers and well as free up some useable space under the hood (better plug/wire clearance)
Old Jan 31, 2003 | 05:38 PM
Actually i was interested in being able to remove my valve covers with more ease, so that i can adjust my rockers with more ease. I dont like having to constantly move the alternator to do so. Any one else?
Old Jan 31, 2003 | 06:01 PM
TTLY-NTS's Avatar
I've relocated the alt to the a/c spot and had some noticed gains. Car reved alot quicker with having alot shorter belt. Best thing was plug access was great. Change'em in 5 minutes.
Old Jan 31, 2003 | 07:16 PM
********TTLY-NTS**********
How did you relocate it?
Old Jan 31, 2003 | 08:03 PM
JIMS1999CONVZ28's Avatar
I need the alt pully part number quick
I have a 1993 Z28 that I am going to use a track car and need to delete the power steering and a/c compressor. I don't care where the Alternator is located, just getting rid of the other tow components.I removed these components but had to put them back on because of the belt will not go from the harmonic pully to the alternator an the lower tensioner pully will not move the belt over with out rubbing on top of itself.
Where did you get the pully to re-route the belt from the harmonic balancer to the alternator? This has got to be a GM part?
Any help would be appreciated and I am following the post on this site were a guy is trying to fabricate a new bracket.
Old Feb 1, 2003 | 07:01 PM
speedmiser's Avatar
Re: I need the alt pully part number quick
That's no problem, both madman
http://www.madmanandcoracing.com/
and steve10
http://www.mycamaroz28.homestead.com/
already make relocation brackets, if you dont mind dumping the power steering. They get rid of the complete pass side accessory bracket along with the tensioner pulley. 1 short belt direct from crank pulley to alt pulley.
I'm running madman's bracket. A bid more expensive - but it was worth it to drive across town and pick it up.
HectorM52
Jul 30, 2017 11:46 AM
Noer
Feb 28, 2015 11:29 AM
Hurin
Dec 13, 2014 07:38 PM
CaRParts102
Dec 6, 2014 08:45 AM
siguy
Nov 27, 2014 10:07 AM
