View Full Version : LT1 Based Engine Tech
- would cut outs trick the sniffer?
- Easy fuel question?!?!?!
- need some new valvetrain parts
- 95 to 97 lt1 swap problems
- Any of you have problems with aftermarket, intank fuel pumps?
- Gains from a stroker
- "Ghetto" Leakdown Question
- Valve springs, intake manifold ect...
- fuel pump voltage
- car feels weird after I reprogrammed for gears
- 36 lbs injectors
- Where can I find a valvespring compressor like this? (pic)
- Those who have installed their own fuel pumps, what kind of fuel-resistant epoxy?
- speedo calibration for '93z with a '94 tranny
- Bilstein shocks
- Running VERY lean at WOT up top
- changing from 52mm-58mm throttle body ?
- Will the LS2 coils work with LTCC?
- DTC 16 low res fail, degrading running conditions, help?
- Fluxuating Oil Pressure + Crackling Sound @ Idle
- Clutch Drill Mod
- Install torque for LT4 rocker covers?
- timing set if I will NOT use OPTI
- Porting MAF-sensor, any idea?
- rubbing help???!!!!asap
- Running guideplates w/ SA Roller Rockers!
- Help a newb out!! (headers)
- Silicone on Water Pump Bolts?
- MPG thread.....how good are you getting
- Are the Hella FF75 DRIVING Lights safe to use as low beams?
- Mufflers for true duals
- Questions about air fittings on Jet Hot's for a 96 LT1...
- Red hot headers ? Rich or lean ??
- bumper supp. replacemet???
- Still want a SPEC???
- when/how to adjust pro mags non self aligning rr
- Optispark *PLEASE HELP NOW*
- HELP!!! lights?
- vented or non-vented opticrapspark?
- cam install question
- Few stroker questions?
- Can i install 4.10 without installations kits
- Engine problem, need help
- a/c removal help
- ATI super damper belt length
- Who has passed emissions test with aftermarket cam? Which one?
- speedo moving while in park!
- Question about crate engines
- Stuck in the middle of cam SWAP!! HELP
- Finished hot cam install....
- 95 Z28 6 speed hit in rear, drivetrain good, $950, what to look for?
- Changing out Oil Pan Gasket/Pump
- my list of mods, what do ya think?
- stumble at cold start up (~1 min.)
- Code question
- 1994 trans am for sale.
- Setting lifters with dial indicator
- Why are fans always on??
- Whoa, 100psi of fuel pressure! Cause?
- Muffler question
- Stupid Question, but are stock cranks
- Gaskets for Jet Hot Longtubes
- Oil Leak from Head Gasket
- oil temp & A/F gauge install
- Good morning!
- Alternator brackets (want to put it where the AirPump was)
- Question about Rocker rollers
- Custom Cam Or Shelf Grind??
- Bottom End Stew.. MUST SEE!!!
- Header Gskts
- Gasket for '96 left exhaust manifold flange?
- Can changing water pump cause an oil leak?
- Head/cam cars what size injectors you running?
- car wont start
- Replacing the water pump....might as well put in a new cam too =)
- Car almost dies right after start up.
- Replaced low oil sensor? Did it break off?
- Braking dims lights, normal?
- How to clean maf?
- Help on 2 quick questions
- starting problems
- how can i get to the stock hp and tq of an ls1?
- Car stumbling bad at high rpm WOT, Bad opti?
- Best Induction/Air Filter Set Up
- PN for cams
- is there a part number for this?
- Misfire problem after plugs/wires PLEASE HELP.....
- Cloyes double roller = mmmmm
- 180 mph
- Oil pressure questions????
- NEED pics of clearances between slp shorties and stock manifolds
- What the best way to get 10yr old Gasket off the block???
- Jet hot longtube headers gaskets
- 36lb injectors...
- Ran the car for about 10 minutes...
- LT-1 Block
- Explain me about Freeze Plugs
- I have my water pump off! Can I get rid of my airpump now??
- Car not startin...
- Trans Am AND Blazer problems!!!
- removed oil cooler, gained 8 psi in oil pressure
- 440-450rwhp Possible with Setup Inside?
- Plug Wires
- Is my starter going out?
- question about GM 847 cam and rear mounted distributor
- LT & Engine Install
- Plans shot...will this still work?
- which o2 sensor is stock?
- Flame Throwing SS
- NON GM Emission Help Needed
- check out my combo and tell me what you think of this upgrade...
- LT1 Solid Roller Questions! Help Please!
- Do I need a Knock Module for my engine?
- Ign Coil
- little question???
- Good Pan or Not....Heard good and Bad...
- Car cranks, won't fire, help please!
- what size injectors and tb to use?
- 1994 b4c problems
- Ignition Control Module?
- Longtubes & Emissions
- Spark plug options.
- T&D Shaft Rockers w/ stock valve covers?
- When recharging AC...
- HELP!!New Motor Problem
- k member and oil pan
- h/c install finished, car runs, but is the oil supposed to look like this?
- dual cat '95
- Not the typical question for headers....
- Maf Elbow Tube
- Do I have a freak LT1 or what?
- No oil at the rockers......
- Corbeau Seats
- Oil pump drive assembly.
- Failed Emissions Test
- 95 T/A Overheating! Help, please.
- electric water pump and weep hole?
- Compression test results
- copper head gaskets
- Frozen Coolant, how overheating
- Knock sensor problems
- Just making sure I got everything I need...
- will 2001 radiator fit in my 96z?
- Adjusting LCA's???
- 4.10 Mpg
- I think I just got done right by dal
- Scorpion 1.7 RR's and Beehives are on.. read the results so far
- 3/8 rocker with 847?
- Installed intake manifold without the bottom baffle
- Where can I buy an alternator relocation bracket for my LT1??
- How much is my engine worth?
- I want a CAI setup like this for my LT1...
- Finished my heads and cam install...
- LT1 questions-intake manifold and rear main
- cc305 plus/minus LT4 Hot Cam kit
- Ignition problems
- engine running like trash any ideas? (bit long)
- Stock LT1 Crank Specs needed
- washer fluid tank removal?
- Will Brand Name LT Headers Make More Power Than Cheap Ones?
- Re-coat Jet hots or go hooker?
- how do I adjust fuel preesure on a 1993 TA lt1?
- Anybody use Accel 375+ with boost retard???
- do i need a fuel FPR?
- Help pulling a lt1 from the top?
- loss of power, missing, and engines somtimes dies
- Caliper replacement and brake bleeding...
- Cammed engine life
- head gasket?
- I just watched my water pump crap out!!!! HELP!!!!!
- Just finished header install, need help with a few "issues"
- Really stupid question.....
- Cammed Audio Clip
- Any gains from polishing intake and TB
- Need help fast!!!
- HP with hotcam
- O2 sensor calibration question
- Painting Intake...quick question about reassembly
- Balancer & Flexplate suggestions????
- Need Torque Spec Quick Please for motor mounts
- Dex Cool sucks! -- Alternatives?
- whatcha' got???
- Will this engine harness work??
- Simple CAI ?
- Crane HI 6 ignition w/o GM-OE coil module
- Oil lines on heads...
- Modifying bumper for ram air, any suggestions?
- Comp 306 in an otherwise stock motor??
- What we be the best upgrade for LT1 intake?
- Would it be worthwhile to make this switch?
- Question about LT4 hot cam kit
- What should I do next?
- CSI install, do you have to install the Diode when putting in a switch
- LT4 Heads and Intake Gains
- Car is misfiring after opti change
- cam or gears?
- Differences in LT1s motors
- tune: can i keep my idle?
- horsepower estimate?
- i almost feel stupid asking this but...
- Stock Oil Pressure/Temperature
- Help my friend pick a cam
- The power of 02 sensors
- Missing?
- LT's installed, engine real rough up to ~1800
- Electrical probelm???
- Low oil pressure = saving for rebuild, need advice on parts!
- Which locators/spacers for CMS EX611 springs?
- H/C first start up tommarow, no tune, should i use stock injectors or the 30#?
- cam install check list
- Big lift cam with smaller duration (218/224 or so)
- Drivability with 42# injectors?
- small oil leak and i think tranny leak!!!
- Anyone know a website with a list of free mods?
- what will happen to LT1 gas mileage if...
- Fuel rail question
- lloyd elliott information
- my lt1 has a rod through the pan where can I buy a new,used pan?
- ltcc plug wires
- Where do I go?
- How much voltage should put to fuel pump to get fuel out of the tank?
- Exhaust question
- Installing Shocks
- the install of my cc306 was more than careless it was horrible!!!
- where is MadZ28 located?
- anyone have this problem
- no coolant crossover on heads bad?
- old school sbc in 4th gen?
- What do you think i'll run with the CC306?
- Is it okay to use gasket maker on the T/B top plate instead of the rubber?
- CC305 OR CC306 whats needed for heads?
- electric water pump wiring question?
- FAILED emmisions test today
- TB gasket
- How do you learn to use LT1 edit software?
- Will a tb and intake from a 97 lt1 work on a 93?
- LT4 starter not fitting correctly?
- 11.5's possible w/ this combo?
- whats the correct way to adjust the valves with the motor off ??
- LT1 Motor Mounts
- Cut-out - Now running rich? Need O2 sim?
- Rusted cam with a little scratch on a surface, usable?
- Car tries to start ... But wont fire AGAIN !!!
- Battery draining in conjunction with clicking at injectors
- cam?
- exhaust
- part number needed for header gasket, not 1406 felpro
- Oil filler cap
- 94 Trans Am T56 Harness
- Header Help
