part number needed for header gasket, not 1406 felpro
Old Dec 22, 2004 | 11:37 PM
30thannZ28's Avatar
I need to know a part number for felpro O-port header gaskets that will match up to the bolt holes on an LT1 motor. I have O-port jet hot long tubes and the D-port 1406 felpro gaskets are leaking because of an improper seal/fitiment issue. Also, will using O-port gaskets somehow be worse on performance and/or gas mileage?
Old Dec 23, 2004 | 02:43 PM
30thannZ28's Avatar
Re: part number needed for header gasket, not 1406 felpro
ttt for today
Old Dec 23, 2004 | 02:50 PM
BUBBA's Avatar
Probably FPP-1426 for "round" 1.59" dia.
Old Dec 23, 2004 | 09:32 PM
atljar's Avatar
I couldnt find any gaskets to match up well to my AFRs and pacesetters, so used high temp RTV and make sure the bolts stay tight. I would guess if the bolts get loose it could cause problems rubbing on the heads, but it seals really well.
Old Dec 28, 2004 | 03:23 PM
30thannZ28's Avatar
thanks a lot bubba, I went and ordered these today and they should stop my leaks. thanks again!
parkers Z28
Mar 11, 2016 08:14 PM
FirebirdGT
Dec 13, 2014 10:25 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
CobraEatr
Jul 22, 2002 09:49 AM
