little question???
Old Dec 27, 2004 | 10:53 PM
ericz28w's Avatar
Smile little question???
hey im getting ready to take out my engine, and i was wondering if there was a easy way to take the wiring harness off of the engine. cause there are a crap load of connections that scare me, so i was just checking before i start taking off all of the connections.
thanks alot guys.
Old Dec 27, 2004 | 11:33 PM
Eff's Avatar
Eff
Re: little question???
It's really not that bad. start with the oil level sensor, and drivers side 02,
then remove the passenges side, plug by plug, then the drivers side. Then pull out the PCM and disconnect it from there.
you may find this extremely useful when trying to put it back on.
http://shbox.com/1/harness.htm
Old Dec 28, 2004 | 08:49 AM
RE AND CHERYL's Avatar
It's really easier to unplug the engine harness from the car and remove it with the engine.
Old Dec 28, 2004 | 10:43 AM
Quick96Z's Avatar
jus use tape and label where all the connectors go, and pull the harness off to the side. Honestly, once you take it apart once, you probably won't even need the tape reminders. The harness is already bent, so when you lay the harness back down when you are ready to reinstall it, the connectors pretty much dangle right next to where they should be. makes it kinda easy. Another helpful thing is to take pictures.
trav
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
