NEED pics of clearances between slp shorties and stock manifolds
Old Dec 28, 2004 | 02:32 PM
lt4 fd's Avatar
I need some pics of mainly fender clearances of the stock manifolds and the 1 3/4" 94-95 SLP shorties... not really JUST fender clearance pics but those would be most helpfull. I know they are supposed to be a direct swap but I wanted to know how tight they are to the engine compared to the stockers.
Old Dec 28, 2004 | 02:43 PM
kingman109's Avatar
Re: NEED pics of clearances between slp shorties and stock manifolds
ill go take some pics for u right now- brb
ohh they are on a 97 - but should be very similar
Old Dec 28, 2004 | 02:56 PM
BlownF1's Avatar
I've got no pics handy, but mine fit fine...they went in from the bottom with the new motor though, so I can't tell you about installation with the motor in the car already. I have pulled the drivers side twice (just moved it out of the way, it was still in the car though) to fix a leaking header gasket and it only took about an hour and a half each time...including pulling all my Aftercooler stuff and reinstalling it. I highly recommend the Breslin bolts...they seemed to have solved my problem with the bolts backing out on #3 and #5 cylinders.
The bigger challenge is plug access, and it's definitely challenging...but with small hands and the right combination of tools it's not too bad.
Dunno if any of that helps any...but there you go!
Old Dec 28, 2004 | 02:59 PM
kingman109's Avatar
here you go - hope those help - engine is pretty dirty and car was about a foot off the ground so had to reach and shoot-
http://community.webshots.com/user/kingman109_us
there should be a new album up in about 20 min called headers-
Old Dec 28, 2004 | 03:01 PM
kingman109's Avatar
ha ya- if u install these def get some locking bolts- i have the same two primaries backing out on mine about every month -
as for changing plugs- id say its nearly as difficult considering the primaries are so big- i currently have about 3 "special" wrenches labeled z28 tools becuase they had to be.... modified..... to make spark plug changes easier-
Old Dec 28, 2004 | 04:40 PM
lt4 fd's Avatar
Awesome thanks for the pics.... is that snow! I see so little here its always exciting BTW its not going into an F-body its going into an 86 rx7 so I was just trying to compare some pics of those headers on an f-bod to some pics of other lt1's under the hoods of 7's to get an idea how much room I have....looks like a lot more than the f-bods have. Thanks again!
Old Dec 28, 2004 | 04:43 PM
kingman109's Avatar
ya def lot more room - buddy of mine has done 3 swaps into RX7's and hes working on another- there are full kits for the conversion available and make it very easy to do - much easier than working on an F-body- im going back to school tommroowo and if i meet up with him ill take some comparison pics of his rx7 hes working on-
hes got another debating throwing a built ls1 in
and yes- lot of snow ha my camaro is my winter car
F'n1996Z28SS
Aug 23, 2023 11:19 PM
nikolt1
Feb 27, 2015 09:10 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
slocody
Feb 10, 2003 01:04 PM
turbo_Z
Aug 19, 2002 10:50 PM
