Help my friend pick a cam
Old Dec 24, 2004 | 08:20 PM
speed_demon24's Avatar
My friend is going to get ported LT4 heads, and is looking for a cam. He DEFINATLY won't rev it past 6K, so I'm telling him to get the crane 210/224. Look at my sig for track #'s bouncin off the limiter and shifting out of the powerband with a slippin tranny. Do you guys have any other cam recomendations for someone with ported heads, but that won't rev it past 6K. I'm telling him not to go too big on the cam or he will just be slower since he will be shifting way too early keeping it out of the powerband.
He also has a 235/235 114 LSA cam, but I think he will be shifting way too early for that cam at 6K and that would make it pointless.
Old Dec 24, 2004 | 08:42 PM
Formula305fi's Avatar
Re: Help my friend pick a cam
Well I've read about the zz4 being a decent option and a cheap one also. Then you could also do a custom grind like 206/236 or something... But I would lean towards the zz4 sounds like a stump puller cam....
Old Dec 24, 2004 | 09:07 PM
Spinner's Avatar
The crane cam would be great for him, with ported LT4s, abig cam is going to make power a lot closer to 68-7000 in a 350, he'd be much better suited to a smaller duration cam with a large lift, on a 114 or larger lobe seperation
Old Dec 24, 2004 | 09:37 PM
Fast Orange's Avatar
is it going to be n/a.. if so i would stick with a smaller lsa the 206.236 sounds ok.. i would check out www.cmotorsports.com their cams make good power.. also the 235 235 114 sounds like a turbo cam..
Old Dec 25, 2004 | 10:38 AM
truedualws6's Avatar
I would also take a look at the GM 845 and the TPIS ZZ9. Both are just a tad
more than the 227. If it's still there, a NIB ZZ9 is for sale on the parts board.
Specs below are with 1.6 rockers:
Crane 104227
210/224 511/553 112
GM 12370845
214/224 521/543 112
TPIS ZZ9
212/226 515/555 112
Old Dec 25, 2004 | 09:53 PM
What about iskys baby cam.
209/217 .465/.485 112
Old Dec 26, 2004 | 10:21 AM
rskrause's Avatar
Moderator
Comp Cams XE lobes #3190/3314 on a 112LSA with 1.6:1 rockers. 214/224 @ 0.050" .600/.570" (1.6)
Rich
rideordie
Nov 5, 2019 04:52 PM
StansZ28
Feb 19, 2015 07:39 AM
pimpss96
Feb 12, 2015 01:28 PM
95chwagon
Jan 13, 2015 09:19 PM
