Code question
Old Dec 29, 2004 | 03:23 PM
BLDun's Avatar
Code question
Did a scan on my Z and found two codes. 77 which is the fan circuit relay and 18 which is the code for injector circuit. However on the readout (freescan) it said code #18 - not used; Any chance this would be programmed out when the dyno was done??? If not then why does it say - not used - ?
Old Dec 29, 2004 | 10:36 PM
BLDun's Avatar
Re: Code question
Anyone?
Old Dec 30, 2004 | 02:01 PM
meengreen 94z's Avatar
Re: Code question
Its probably a manufacturer specific code, meaning you need the GM scantool chip or a GM manual to see what it is. I could probably tell you what the code is, but my books are back at my apartment.
Old Dec 30, 2004 | 02:24 PM
Re: Code question
You can find a pretty accurate list of codes for our cars here.
18 is used.
Old Dec 30, 2004 | 10:59 PM
BLDun's Avatar
Re: Code question
I know what the code is for - #18 is listed as injector circuit. What I don't understand is why is it listed on the freescan monitor exactly like this:
18 - not used. If it is used then why this message and if it is an injector circuit problem why this message? Also, if it is an injector circuit problem exactly what does that mean?
Old Dec 31, 2004 | 12:35 AM
Re: Code question
Seems like it's a Freescan issue. It means the PCM sees an improper voltage on one or more of the injectors. Check the injector wiring with a meter and check the resistance of the injectors.
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
cmdeshon
Dec 27, 2014 10:06 AM
Jul 4, 2005 05:00 PM
johnsocal
Aug 29, 2002 10:01 AM
91Bird305
Aug 5, 2002 01:39 PM
