small oil leak and i think tranny leak!!!
Old Dec 24, 2004 | 12:00 AM
crAzy95z28's Avatar
ok, well i started to notice alot of oil runing down my starter and on the back of my ac compressor, and run all down the tranny pan...it usually drops a few drops on the ground.....
Now on the tranny i see purple liquid right at the tip of it behind the tranny mount!!!
I check my fluid every 2 weeks to be sure its ok, but is this bad at all?
Im thinking it may be the dip stick tube causing the oil to come out bc i do nOT have it bolted down cause of the LT headers!!!
please let me know ASAP!!!
Randy
Old Dec 24, 2004 | 10:53 AM
ChickenScreamer94's Avatar
Re: small oil leak and i think tranny leak!!!
I am going to say you have two leaks. The first is most likely the intake manifold leak, which is leaving the oil on your starter. Since you say your dipstick isn't bolted down right, you may have answered your own question. Those are just guesses.....
Check the tailshaft on the transmission for cracks or other damage. Clean up the area as well as you can with carb cleaner, then check again in a day or two to see where its coming from.
Old Dec 24, 2004 | 12:22 PM
neil350's Avatar
fix the dip stick, thats prolly it, other wise your intake manifold be leaking
Neil
Old Dec 24, 2004 | 03:31 PM
crAzy95z28's Avatar
nope intake is not leaking, ive checked back there plenty of times!!!
rubed with my hand and no oil...
its been replaced n e ways!!
Magenta_Hearts
Mar 29, 2017 08:54 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
BigWil
Mar 29, 2015 12:24 PM
mattszm6
Dec 14, 2014 07:09 AM
siguy
Nov 27, 2014 10:07 AM
