Can i install 4.10 without installations kits
Old Dec 29, 2004 | 09:12 PM
ozzycamaroz28's Avatar
hi,i broke recently my 3.73 gears ,i bought a 4.10 motive gears but i research here in lt1's that you need full installation kit with the solid shim.can i install without spacers;etc.etc.???i dont plan to put in slicks
Thx for info
Old Dec 29, 2004 | 09:44 PM
dmoor88's Avatar
Re: Can i install 4.10 without installations kits
not the best idea unless you want them going bad quickly. spend the extra $$$.
Old Dec 29, 2004 | 10:27 PM
SnakeSkinner28's Avatar
No way should you do it without spacers. Youll have so much backlash that youll probably be breaking teeth off in a week. Spend the 50 or so dollars and do the job properly.
Old Dec 30, 2004 | 12:20 AM
1racerdude's Avatar
The 4.10 ain't gonna last either,if it's a factory rear end.Pinion is to small to take the load.It is no bigger than an egg. All you need is a crush sleave and a pinion nut and ring gear bolts and get the inner brg pressed off and on the pinion.If you get a GMHP ring and pinion you shouldn't need shims.Check the backlash with a dial indicator and see after you install it. The carrier shims are easy to change and leave the shim under the inner pinion brg like it is.
Old Dec 30, 2004 | 12:25 AM
FryedClutch's Avatar
i dunno if i were you id want to replace all the bearings if i broke the gears cause there is prolly a bunch of crap that worked its way into everything but thats just me
Old Dec 30, 2004 | 12:33 AM
1racerdude's Avatar
He's just going to have to replace them again in a short time anyway,when the 4.10 breaks,and it will. Probably wasn't run far enough after the breakage to have hurt the brgs.
Old Dec 30, 2004 | 12:49 AM
dmoor88's Avatar
if you have a choice go with the 'thicker' 4.11's
Old Dec 31, 2004 | 01:38 PM
thx all for the answers i will buy it thx all happy new year!
Jan 23, 2015 01:13 PM
Dec 4, 2014 11:56 AM
Don 97 SS
Jul 11, 2005 08:50 AM
