fuel pump voltage
Old Dec 30, 2004 | 05:04 PM
scott's94z's Avatar
fuel pump voltage
i just got the Walbro 255 lph pump from racetronix (just the pump assembly) and i was wondering what kind of voltage the pump will see without the booster wiring harness. i noticed the pump is rated at 13.5 volts, but is that the stock voltage at the pump or the voltage with the plug and play harness?
Old Dec 30, 2004 | 07:09 PM
Robs97Z28's Avatar
Re: fuel pump voltage
this sould tell you everything you wanted to know and why.
http://www.racetronix.com/Racetronix..._Pump_Kit.html
grabbem88
Mar 18, 2015 01:25 PM
Scottyboy
Feb 11, 2015 10:28 PM
Gtpguy
Jan 26, 2015 04:50 PM
ANDYZ28
Dec 29, 2014 09:13 PM
