Optispark *PLEASE HELP NOW*
Old Dec 29, 2004 | 09:55 PM
99BlackTA's Avatar
Well I know there has been a million posts about them but here is mine. I bought one the other day and just had it installed on the car to see if that would fix the problem that I had been having. I have the Delteq system currently installed on my car. The mechanic just got it all installed and said the car keeps turning over but it never starts. He said the optibox isn't lighting up either like it isn't getting a signal. Does this mean the optical portion of the optispark is dead in this new one? PLEASE HELP!!
Old Dec 30, 2004 | 05:16 PM
stew's94z's Avatar
Re: Optispark *PLEASE HELP NOW*
I've got to bump this one.
The brother needs some help.
Old Dec 30, 2004 | 05:54 PM
30696bird's Avatar
Not sure but maybe this will help....... http://shbox.com/1/4th_gen_tech2.html#opti_test . Good luck figuring it out. If you find out what the problem is be sure to post it in case the problem happens to someone else.
Old Dec 30, 2004 | 06:59 PM
Robs97Z28's Avatar
how old is the deltec? You might have a problem with the harness from the injectors to the opti box. I would first check that you are receiving a signal from the opti, as stated above. good luck.
Old Dec 30, 2004 | 07:09 PM
Pasky's Avatar
Opti may be on wrong as well.
Old Dec 30, 2004 | 08:35 PM
99BlackTA's Avatar
Delteq is less than 2k miles and one moth old.
Old Dec 30, 2004 | 10:00 PM
Robs97Z28's Avatar
They have sinced fixed the harness. so, you don't have to worry about that. Some of the first harness had a soldering issue.
Old Dec 31, 2004 | 10:37 AM
99BlackTA's Avatar
*UPDATE*
Installed a brand new opti this time and it fired right up. Took it for a test drive and brought it back to the shop. Turned it off and tried to restart it. Nothing at all. The coils in the Delteq system don't seem to be firing at all. Everything in the system has ground and power though.
Disconnected and removed all the Delteq off the car and then installed stock ignition system with delco plug wires. Car fired right up and runs perfect. No problems starting/restarting or anything. I think it might have been in the opti-box but I am not positive. I am now really more than ever just wanting it back to stock and ready to drive daily again without any problems. I think everytime I modify my car something seems to go terribly wrong with my luck.
Thanks again for the help fellas. I sure needed it.
Old Dec 31, 2004 | 02:28 PM
Kataklysm's Avatar
[QUOTE=ElectronBlueC3]I am now really more than ever just wanting it back to stock and ready to drive daily again without any problems. I think everytime I modify my car something seems to go terribly wrong with my luck.
QUOTE]
Thats why I am not planning on anything besides suspension/rear end work!
Old Dec 31, 2004 | 02:32 PM
MentalCaseOne's Avatar
Ha Ha... I feel the same way about mine. I installed roller rockers and now I am driving a friggin sewing machine!! I isntalled a ES tranny mount and I may aswell be sitting on the engine itself...
I know I exagerate a bit but I bet when I isntall ES bushings all around its gunna feel like I am riding on the bare Wheels too..
Marvin
Edit: Dang I just realized I hijacked your thread... I apologize
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
colts0455
Sep 27, 2015 01:07 PM
Z Power
Sep 19, 2015 11:19 PM
