horsepower estimate?
Old Dec 24, 2004 | 09:33 PM
93black-ta's Avatar
can anyone tell me a rwhp estimate with these mods?
383 stroker w/ around 11:1 comp
crane cams 230/236, 544/554
long tubes
all the bolt on's
electric water pump
heads- gasket matched ,polished combustion chambers
Old Dec 25, 2004 | 12:57 AM
dmoor88's Avatar
Re: horsepower estimate?
what sort of heads?
Old Dec 25, 2004 | 09:32 AM
93black-ta's Avatar
they are stock heads
Old Dec 25, 2004 | 10:13 AM
JIMS1999CONVZ28's Avatar
Just guessing based on my 383, I would say 340-350 at the rear wheels based on an automatic.
My old 350 with a 230x236 put out 305 hp but ran 12.2 with 3:23 gears and with the 4:56 gears it did not have enough rpms to make it to the finish line but still ran a 12.3 ( I feathered the gas at 6500 rpms to finish). I also had only an alternator to drive plus the WP but the electric WP will not give you that much of an increase in HP.
My 383 to 12:1 cr, Lloyds head, 2.055" intake 1.6" exh valves and a Solid Roller cam made 401 hp at the rear wheels with a turbo 400 and 500 HP off the flex plate. Keep in mind also that my car weighs only 3000 lbs.
One other thing; I am pulling the old 350 apart and selling the 230 x 236 .050 @ 112 and the CM .600" lift springs as I need the block to build another 383.
Jim , Orlando fl
Old Dec 25, 2004 | 03:33 PM
dmoor88's Avatar
yea youll prolly just see another 10rwhp over stock ci until you get the heads worked over sounds like a nice setup though...
Old Dec 25, 2004 | 08:44 PM
ninetythreez's Avatar
10 hp over stock with all those other mods added until heads are worked on?
wanna rethink that?...
Old Dec 25, 2004 | 10:11 PM
dmoor88's Avatar
read what i typed again. I said 10rwhp over stock ci, meaning a 350. If everything remained constant except for going from a 350 to a 383, you'd only see about a 10rwhp gain if you havent had the heads worked.
IndyZman
Oct 22, 2015 02:17 PM
Aug 24, 2015 06:41 AM
Slayer
Aug 17, 2015 03:55 PM
karpetcm
Aug 14, 2015 03:02 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
