Finished my heads and cam install...
Old Dec 26, 2004 | 10:26 PM
'94 Bad A Z28's Avatar
... buttoning everything up, but where does that plug on the same line as the Air Intake Temp. plug go? I believe it is for the water pump, but where does it plug in?
Old Dec 26, 2004 | 11:27 PM
Re: Finished my heads and cam install...
Here is a QUICK video of the first start up...
http://www.fuelslut.net/personal/theheadfl/mov02010.mpg
You will need the divx codec installed to view this. You can download that at http://www.divx.com/divx/download/
Old Dec 26, 2004 | 11:36 PM
Formula305fi's Avatar
Sounds sweet man.... I havent been out to the corner since my fiances wreck, but ill get out there to take a ride in that... (I'm the guy Ryan called to help em with his oil-pan gasket)
-Justin
Old Dec 26, 2004 | 11:48 PM
Ohhhhh okay... I was like, who are you, lol.... okay I remember... yeah you whould come out sometime.
Old Dec 27, 2004 | 12:41 AM
redcamaroz28's Avatar
That plug goes to the water temp sense which is located on the bottom/drivers side of the water pump. It's right by the bottom hose.
For some reason I still can't see the video after downloading the codec, but I'll just wait and see it running in person instead. Congrats!
Old Dec 27, 2004 | 01:03 AM
Cool thx.... see ya later, CrAzY!
Old Dec 27, 2004 | 07:01 AM
97s10ondubs's Avatar
I just finished my LE2 h/c setup yesterday, but broke the oil pump driveshaft assembly and had to get a new one, I did fire it up though, and had no oil pressure and had to shut it off. Sounded mighty bad *** though, im going to post a vid of mine when I'm done too. Just for curiousity's sake, how long did it take you and what problems did you run into?
Old Dec 27, 2004 | 08:49 AM
The car was down for a long time because I was waiting for my friend that works at a GM Performance shop to come over and help. I finally gave up on that and I prolly worked on it for about a total of 18-22 hours. 'Cause I had no clue what I was doing, lol.
Old Dec 27, 2004 | 06:43 PM
Showme's Avatar
Congrats on the H/C install. Beleive or not, I'm sure you learned a whole lot from the experience. I'll bet if you had to do it again, you could do with one arm tied behind your back.
I broke my oil pump drive shaft assembly too, LOL
Take Care,
Tim
StansZ28
Feb 19, 2015 07:39 AM
kaoticcamaross
Feb 17, 2015 03:13 PM
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Nov 20, 2014 06:03 PM
