95 to 97 lt1 swap problems
Old Dec 30, 2004 | 06:25 PM
gtkilr95's Avatar
O.k. to start I have a 95 lt1 trans am. I put a 97 motor and brain in my car. The 97 has more sensors then my 95. well this effect my engine because I noticed there is some plugs next to my manifold and some for my crank sensor. Can some one advise me what to do.
Old Dec 30, 2004 | 06:52 PM
Re: 95 to 97 lt1 swap problems
Did you change to the 1997 the wiring harness, too?
If you are using the 1995 harness (or even the 1997), just use the 1995 computer and you don't have to worry about the extra sensors.
Old Dec 30, 2004 | 07:52 PM
gtkilr95's Avatar
no not yet but do I have to? I would like to know what the other sensors are for and are there any diff between the motors
Old Dec 30, 2004 | 09:48 PM
My previous post indicated you could use either harness. With the 97 computer, there is the EVAP vaccum switch, rear O2 sensors and crank sensor that are monitored that you won't be able to wire up using the 95 harness. Other than that there is virtually no difference.
rocketman051894
Jan 30, 2015 03:23 PM
InfernalVortex
Jan 17, 2015 09:35 AM
cmdeshon
Jan 4, 2015 11:15 AM
Ricardo
Nov 29, 2014 10:58 AM
