Is it okay to use gasket maker on the T/B top plate instead of the rubber?
Old Dec 23, 2004 | 02:19 PM
BlackLT1_TX's Avatar
Mine is all jacked up, can I just use gasket maker?
THanks,
James
Old Dec 23, 2004 | 02:44 PM
BUBBA's Avatar
Re: Is it okay to use gasket maker on the T/B top plate instead of the rubber?
I suppose you can use it, but I wouldn't use it if it has silicone in it, since it might throw your 02s into a frenzy. JMHO
Old Dec 23, 2004 | 03:01 PM
indieaz's Avatar
How is silicon on the throttle body going to throw off the O2s??? I would just be sure to clean it up after it dries. You thinkt he TB is going to get so hot that gasses are let off from the gasket maker?
Old Dec 23, 2004 | 03:05 PM
BUBBA's Avatar
I can't say for certain that it will affect anything. Just wouldn't want any of the fumes to get into my intake system and would opt for something without the silicone to be on the safe side. That's just me.
Old Dec 23, 2004 | 03:51 PM
Evil Eric's Avatar
the lines on the top plate of the t/b go the the evap canister solinoid vaccum and the suction side of the pcv system on the top of the passenger side of the valve cover. i have mine sealed on with mega blue gasket maker, you will be fine.
Old Dec 23, 2004 | 03:58 PM
NOMAD's Avatar
Close
The top line runs to the PCV system, the bottom line runs to the EVAP. The bottom line runs to a machined vaccum port on the back of the TB
You can use anything to seal it. The only thing it will affect is vaccum if you don't get it to seal properly. The vaccum from the front of the TB is what works part of the PCV system. I suggest using a thin piece of cardboard with a little sealant around it just to make sure.
-Shannon
Victor Lamb
Aug 26, 2017 02:52 PM
Jun 6, 2015 08:27 AM
Jazsun
Dec 29, 2014 12:14 PM
siguy
Nov 27, 2014 10:07 AM
