36lb injectors...
Old Dec 28, 2004 | 01:15 PM
'94 Bad A Z28's Avatar
36lb injectors...
... I have 36lb injectors sitting in my room for my heads/cam car. Do you think it would be okay to put them in and run the car or should I wait to get some type of quick tune for the injectors on the car first then put them in?
Old Dec 28, 2004 | 01:20 PM
SS MPSTR's Avatar
Re: 36lb injectors...
I'd wait for the tune before I dropped in those injectors.
Old Dec 28, 2004 | 01:21 PM
ejfagala's Avatar
Your car will run way rich and worse with just sticking in the injectors if you don't tune for them. Unless your stockers are causing problems I would leave them in.
Old Dec 28, 2004 | 01:22 PM
I'll wait for a quick tune then, or atleast untill the car is getting ready to be trailered for a tune.
Old Dec 28, 2004 | 02:48 PM
Flyin_Z28's Avatar
Your right, you should wait to tune your car first before you install the 36's.
You could risk the chance or washing down your cylinder walls if you install them w/o a tune.
Why are you going to trailer your car to get a tune? Just drive it there with the stock injectors. You should be fine. Just make sure your car is running properly before you drive it.
Old Dec 28, 2004 | 05:50 PM
Because the place I am getting it tuned is 100 miles away from me. That and the car doesn't even like to drive in my neighborhood untuned, lol.
Old Dec 28, 2004 | 07:40 PM
redcamaroz28's Avatar
Stop being a baby and drive the biatch there how it is now (w/o the y-pipe too ) I'm actually surprised your car runs and idles as well as it does w/ the stock tune and your heads and small cam.
Old Dec 28, 2004 | 07:48 PM
SS MPSTR's Avatar
I drove around with the stock injectors for a short period, and my set-up is considerably more aggressive.
onefastgta
Mar 19, 2015 10:09 AM
Schurters LT1
Nov 28, 2004 10:07 PM
Schurters LT1
Nov 27, 2004 03:13 PM
Silvershark
Parts Wanted
Sep 11, 2004 10:50 PM
donot_4get
Aug 30, 2004 12:40 AM
