what size injectors and tb to use?
Old Dec 27, 2004 | 09:36 PM
bbuice's Avatar
I am building a 383 with 11 to 1 compression I plan on using a cc306 cam what size tb and injecters do I need?also do I need an adjustible fuel pump regulator?I plan on using a 100 shot or maby a 150 shot nos later.Is this a good cam choice for a 383 with ported heads and 11 to 1?Thanks!
Old Dec 27, 2004 | 09:38 PM
fesgali's Avatar
Re: what size injectors and tb to use?
52mm tb
36lb or a 40lb injector doesn't seem bad
Old Dec 27, 2004 | 09:40 PM
Mystic97Z's Avatar
i will have a 383 stroker set up with a 58mm and 30# injectors
what are the specs on that 306 cam? i see alot of people puting that in their 383 strokers..i talked to lloyd about his LE3 cam, and i think thats what i'm going with.
-Jason
Old Dec 27, 2004 | 09:47 PM
bbuice's Avatar
what rw hp can I expect from this combo?
Old Dec 27, 2004 | 10:55 PM
1racerdude's Avatar
If you are serious about HP then 42lb'rs @45PSI and a 1300CFM AS&M mono blade is the ticket. You can make 650-700FWHP with this set up.
Not the best cam but OK depending on your head numbers.
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
QuickSilver02
Apr 7, 2015 11:12 AM
drptop70ss
Mar 26, 2015 01:50 AM
