Help on 2 quick questions
Old Dec 28, 2004 | 07:47 PM
94zLT1's Avatar
Hey guys i got 2 questions..
1. I have MAC mid headers and the egr tube that comes off the passanger side rear primary that bolts to a egr tube from the engine may be leaking just a tad..its held together with 1 bolt but isint exactley flush...what type of high heat lube/goo/sealant can i use there to make sure no air is leaking into the tube thus skewing my 02 readings...as i said it is miniscule and im not even sure its leaking but id rather be safe than sorry...whats the best type of sealant that will not burn off, will not allow air in/out, and will adhere well?
2. I am in the process of putting on a hooker catback...to "hang" the muffler/catback as u all know i need to use hangers..now the ruber pieces are on the car and the hooks are on the pipes but it says to use the stock hangers and i do not have them anymore. Where can i get these? local exhaust shop/pep boys/AZ/napa? What r the chances a local exhaust shop would have stock 94Z28 exhaust hangers?
much appreciated
Old Dec 28, 2004 | 08:01 PM
Kataklysm's Avatar
Re: Help on 2 quick questions
1. Use copper RTV sealent, put it on and let it set for a while, best if sits for 24 hours.
2. I doubt they will have "stock hangers" but they could fab up what you need if they are any good.
Old Dec 28, 2004 | 08:11 PM
94zLT1's Avatar
ya thats the thing i wanted to put on the catback myself and i cant unless i have those hangers..if i go to a shop they are going to want me to bring it in and then chanrge me to put on the cat back that i can do in 10 mins in my garage
Old Dec 28, 2004 | 10:49 PM
1racerdude's Avatar
Go to Home Depot and get some stock and make some.
Old Dec 29, 2004 | 12:13 AM
Rockin94Z's Avatar
go to the dealer im pretty sure you can pick up hangers and the lil rubber mounts pretty cheap. if all else fails just the the ends off some 12" long nails and bend them, then weld them in to place
Old Dec 29, 2004 | 12:34 AM
94zLT1's Avatar
ya guys all good ideas but im retarded and i see how it hooks up..there is an extra little metal L piece that hooks up the drivers side outlet but no piece for the passanger side oulet...i have the rubber fittings on the car.
someone who has hooker should chime in
Old Feb 16, 2005 | 01:45 PM
blind527's Avatar
the stock hangers don't fit on my random tech cat back system, what can i do to solve this?
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
Jan 23, 2015 01:13 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
