k member and oil pan
Old Dec 27, 2004 | 05:13 PM
nigsrig's Avatar
i have a bmr k member and was wondering if the stock oil pan will come out with this setup without having to undo anything it looks like there is enough clearance to get it out and will the canton oil pan fit tjis k member
Old Dec 27, 2004 | 06:31 PM
Dave89IROC's Avatar
Re: k member and oil pan
maybe
it gives you lots more room
Old Dec 28, 2004 | 04:39 PM
nigsrig's Avatar
no one has had first hand experience with doing this?
Old Dec 28, 2004 | 11:01 PM
1racerdude's Avatar
The Canton will fit,I am running one.You have to put torque washers(thick) between the block and motor mount(doesn't hurt a thing) to stop rub on rack. Don't know about taking it off but you can get a stock pan off of a stock K member by jacking the engine up. So it "should" come off. You may have to turn the crank while coming off.
Old Dec 29, 2004 | 08:05 AM
sssalah's Avatar
Sorry, don't mean to hijak this thread, but I'm going to install the bmr k-member tomorow, and have the canton pan. How thick are these washers and doesn't that affect driveline angle.
Old Dec 29, 2004 | 01:14 PM
1racerdude's Avatar
About 1/8" and they won't effect the angle enough to worry about. Shaft angle is not a 1/8" science.
Old Dec 29, 2004 | 04:44 PM
WS Sick's Avatar
I agree with most of whats been said (is that correct grammer?... ), but when I changed my oil pan I had to jack up my motor and loosen the K member bolts to get the stock pan out.
HectorM52
Jul 30, 2017 11:46 AM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Elcojoe
Nov 17, 2014 10:27 PM
