no coolant crossover on heads bad?
Old Dec 23, 2004 | 03:30 PM
97s10ondubs's Avatar
I ask this because im in the middle of a h/c swap and my old heads do not have the coolant crossover just two plugs on the heads, they have been like that since i bought the car in march, so I do not have a pipe and was wondering if it was ok to take the plugs and put them in the new heads. If not where do I get a pipe and how much?
Old Dec 23, 2004 | 04:20 PM
NOMAD's Avatar
Re: no coolant crossover on heads bad?
Not good, do a search to find out why
-Shannon
Old Dec 23, 2004 | 04:25 PM
F(ast)-body's Avatar
you say the heads that were on the car were plugged...I can't imagine why someone would do that. Did the car remain at normal temperature? You can get the crossover tube at any GM dealer usually between $55-$60...
Old Dec 23, 2004 | 06:01 PM
OBE1 95Z28's Avatar
This pipe allows steam to be extracted from the heads...install the pipe!
Old Dec 23, 2004 | 07:09 PM
firetird's Avatar
i ran my car without the tube for about 1 1/2 years with no problems.
Old Dec 23, 2004 | 09:02 PM
It would be best to have the pipe on there. P/n for the set is on my Part Numbers page.
Old Dec 23, 2004 | 10:41 PM
tanker's Avatar
I have an extra one laying around
Old Dec 24, 2004 | 06:27 AM
the car never overheated and ran at 170 maybe temp its right above 160, never gave me any trouble
Old Dec 24, 2004 | 06:34 AM
Dave89IROC's Avatar
yeah, but you are getting hot spots at the rear of the heads(which is bad for valves and gaskets), the sender for the gauge is at the front of the head, the tube allows coolant to flow through the dead spot at the rear of the heads
Old Dec 24, 2004 | 06:46 AM
can i put this tube on with the heads in the car, or can i buy the fittings at a hardware store? everything is almost put back together and im not gonna take the heads off
Old Dec 24, 2004 | 07:01 AM
Dave89IROC's Avatar
you can do it with the heads on, but the parts are dealer only
Old Dec 24, 2004 | 11:43 AM
ok well ima leave it until i get a chance to go to the stealership
HectorM52
Jul 30, 2017 11:46 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
