when/how to adjust pro mags non self aligning rr
Old Dec 29, 2004 | 10:02 PM
fstenuf's Avatar
i was wondering when/how often i should adjust my rr's? i have pro mags 1.6 rr's.
also i was wondering if i need to worry about the rr's hitting directly in the center of the valve and how to know if it is hitting the valve properly. i think i read somewhere about marking the valve with a marker and paying attention to where the rocker rubs the marker off and adjusting it. but i can't find that mag. any help or info would be great. thanks!
Old Dec 30, 2004 | 12:39 PM
stereomandan's Avatar
Re: when/how to adjust pro mags non self aligning rr
The marker technique you are referring to is for checking the pushrod length. You have the GM guideplates correct? They hold the pushrods in the correct position throughout the pushrod travel. A visual inspection should be adequate.
They should only need adjusting once, but may loosen up after the first few miles if there were any burrs preventing perfect contact the first time. Then they need to be done a second time if they loosen up. After that, they should be good.
I'm fairly sure that you can find the marker technique that you are referring to on Comp Cams website. www.compcams.com It would be in the pushrod section, for instructions.
Dan
Old Dec 30, 2004 | 08:05 PM
fstenuf's Avatar
ok thanks for all your help! that marker technique has been buggin me for so long now glad you got 'er figured out for me thanks!
i only have like 1000 miles on the new motor set up, so i think i'll have everything checked out in the spring so i'm ready to roll for the summer! thanks
Quickss96
Jan 29, 2016 05:56 PM
93 RedBird
Nov 15, 2015 08:24 AM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
realistyc
Jul 28, 2015 07:32 PM
